Today is the 30th anniversary of the very first part we ever made for the 914, our beloved 914 door latch cam. A simple little part eliminated the need to purchase a complete exterior door latch back then, and set a trend for filling a need in the 914 community for parts that were either too expensive, had to be purchased as an assembly, or discontinued by the factory (and more and more these days the latter is true! Here is a list of the over 275 parts we make for that fabulous car, with new additions added every year. Our latest additions will be 1.8 throttle body boots both 74 and 75 style, engine lid drip pans in exact factory concours duplication, and a long sought after tow eye for you concours buffs, tool kits! We are always here for you our fellow 914 enthusiast and detailed CORRECT tech advice is only a phone call or e mail away George Hussey dr914
B021109345A,PUSHROD TUBE SEAL VITON
B021109349B,PUSHROD TUBE SEAL LARGE LATE 70-76 VITON
B021119149,FAN BULLET CAP
B021119187,BEARING SHELL BELLOWS FLAPS
B021119233A,TIMING HOLE PLUG
B021119264A,ENGINE FAN FLAP
B021119295,ALTERNATOR COVER PLATE OVAL FOR ENGINE SHEETMETAL 914
B021119553,GROMMET FOR COVER PLATE
B021119627B,J PIPE GROMMET
B021119955,THERMOSTAT CABLE SEAL
B021119957,OIL PRESSURE SWITCH BOOT
B021129967P,THROTTLE BODY BOOT 1.7L
B021133033BJ,ENGINE COMPARTMENT DECAL STICKER; 1973; 914; 1.7
B021251067A,MUFFLER BRACKET; 914 1.7 1.8 1970-74
B022100175,VALVE ADJUST DECAL STICKER; 914 1.7 AND 1.8
B022101559,WINDAGE TRAY OIL BAFFLE SEAL 914-4 ALL FOUR REQUIRED
B022119356A,LEFT AIR GUIDE PLATE 1973-74
B022129637B,STACKED VACUUM ELBOW
B022129967P,ELBOW FOR AIR FILTER; 914 1.7 1970-73
B022129967T,ELBOW HOSE 1974 1.8 TO AIR FLOW METER
B022133033BG,ENGINE COMPARTMENT DECAL STICKER; 914; 1974; 1.8
B022133033BH,ENGINE COMPARTMENT DECAL STICKER; 914; 1975; 1.8
B022133033BJ,ENGINE COMPARTMENT DECAL STICKER; 914; 1976; 2.0
B022251067A,MUFFLER BRACKET; 914 1.7 1.8 1970-74
B022256121,WARM AIR ELBOW
B022256511,REAR BRANCH PIECE CLAMP
B022906102,2-POLE INJECTOR PLUG LEAD BOOT
B039100175,VALVE ADJUST DECAL STICKER 2.0; 914
B039119353,LEFT AIR GUIDE PLATE 1975-76
B039133033BJ,ENGINE COMPARTMENT DECAL STICKER 2.0; 914 1974
B
B039251067,MUFFLER BRACKET; 914 2.0 914-6
B111012115C,REPRODUCTION TOOL BAG
B111201261,SINGLE IGNITION WIRE CLIP
B311201231A,FUEL (GAS) TANK STRAINER NUT SMALL HOLE
B311905227C,DISTRIBUTOR POINTS PLATE WITH POINTS 914-4
B311906101,FUEL PUMP BOOT
B311949149A,OIL TEMP SENDING UNIT BOOT
B411000263A,91 ROZ OCTANE RATING STICKER
B411261813,REPRODUCTION RIGHT J-PIPE COVER
B411837095,INTERIOR DOOR HANDLE CUP
B477853381,GRILLE INSERT 924 TURBO FOUR REQ
B477863517B05T,LUGGAGE COVER CAP -BLACK
B477871217,944 FRONT SUNROOF LATCH HANDLE LEFT OR RIGHT
B64455203300,STEEL DASH BOARD (DASHBOARD) TOP UNCOVERED WITHOUT INTERIOR LIGHT CUTOUT 356
B64455203307,STEEL DASH TOP UNCOVERED WITH INTERIOR LIGHT CUTOUT 356
B64457269106,VENTILATION FRESH AIR CONTROL BOOT LEFT 356 T6
B64457269206,VENTILATION FRESH AIR CONTROL BOOT RIGHT 356 T6
B64463140300,NORTH AMERICAN LEFT TAILLIGHT ASSEMBLY 356
B64463140300S,NORTH AMERICAN LEFT/RIGHT TAILLIGHT ASSEMBLY SET FOR 356
B64463140310,EUROPEAN LEFT TAILLIGHT ASSEMBLY 356
B64463140310S,EUROPEAN LEFT/RIGHT TAILLIGHT SET; SAVE $11.99
B64463140400,NORTH AMERICAN RIGHT TAILLIGHT ASSEMBLY 356
B64463140410,EUROPEAN RIGHT TAILLIGHT ASSEMBLY 356
B64472101001,REPRODUCTION 356 TOOL BAG
B823837239,DOOR HANDLE TRIM
B90024101102,RELAY BOARD COVER NUT
B90100650200,FIRING ORDER DECAL STICKER 914-6
B90100650300,VALVE ADJUST STICKER DECAL 914-6
B90100650401,OIL LEVEL STICKER DECAL 914-6
B90100650800,ALTERNATOR DECAL STICKER 914-6
B9010065SET,5 PIECE ENGINE LID STICKER SET 914-6
B90142401300,SHIFT KNOB PUSH ON TYPE. FITS 1967-1971 (4 SPEED)
B90142401400,5 SPEED SHIFT KNOB; 914 1970-76 912 1965-69 911 1965-71
B90150115321,JACK POST RECEIVER; 911 912
B90150139000,PEDAL BOARD BRACKET
B90154248220,INSIDE WINDOW CRANK COVERING
B90155281320, engine lid RELEASE CABLE knob
B9016025300, "MARELLI" DISTRIBUTOR CAP 914-6/911
R90160292801 marelli distributor rotor 914-6 911
B91131802900,SPEEDOMETER ANGLE DRIVE
B91142407101,SHIFT KNOB; 911 1972-86 916 912E 1976
B91142422303D,SHIFT COUPLER U-JOINT BUSHING DELRIN
B91153163SET,OUTER DOOR HANDLE SEAL KIT 911; 10% OFF!
B91154247100,SIDE WINDOW CRANK CHROME
B91154247101,SIDE WINDOW CRANK BLACK
B911542471BKIT,BLACK WINDOW CRANK SET WITH COVERS 911 AND 912; 10% OFF!
B911542471CKIT,CHROME WINDOW CRANK SET WITH COVERS 911 AND 912; 10% OFF!
B91161362103S,POWER WINDOW SWITCH SET
B91163143203,REAR UPDATE KIT BOLT ON WITH PORSCHE SCRIPT
B91172202101,AUTO JACK BRACKET
B91173103117CA9,REPRODUCTION LEFT SUN VISOR COUPE BLACK VINYL
B91173103117CC4,REPRODUCTION LEFT SUN VISOR COUPE BLACK/WHITE VINYL
B91173103161,REPRODUCTION LEFT SUN VISOR TARGA BLACK VINYL
B91173103217CA9,REPRODUCTION RIGHT SUN VISOR COUPE BLACK VINYL
B91173103217CC4,REPRODUCTION RIGHT SUN VISOR COUPE BLACK/WHITE VINYL
B91173103261,REPRODUCTION RIGHT SUN VISOR TARGA BLACK VINYL
B91173103509,FACTORY LOOK MIRROR GLASS; 924 1976-85 924S 1986-88
B91173132341,LEFT VISOR CLIP
B91173132441,RIGHT VISOR CLIP
B911731KIT,SUNVISOR CLIP SET
B91400650100,TIRE PRESSURE DECAL STICKER 914-6
B91400650510,165 TIRE PRESSURE STICKER
B91400650511,TIRE INFLATION STICKER
B91420115310,FUEL (GAS) TANK STRAINER NUT; LARGE HOLE
B91430317300,LOWER WASHER (SHIFT ROD AND FORKS) 914-4 1.7 1.8 2.0
B91431802901,SPEEDOMETER ANGLE DRIVE
B91433153303,CONTROL ARM PLATE 2MM
B91433153303SET,CONTROL ARM PLATE SET - 1 2 & 3MM
B91433153304,CONTROL ARM PLATE
B91433153305,CONTROL ARM PLATE 4MM
B914352423A,REAR CALIPER INNER ADJUSTER
B914352423B,REAR CALIPER SMALL 8MM OUTER ADJUSTER; 914 EARLY REAR CALIPERS
B914352423C,REAR CALIPER INNER ADJUSTER CAP 914
B914352423D,REAR CALIPER LARGE 10MM OUTER ADJUSTER; 914
B91435291800,INNER ADJUSTER CAP
B91436130500,BLACK PLASTIC CENTER CAP FOR STEEL WHEELS
B91442407305,CONSOLE HEATER LEVER HANDLE
B91442416902,RUBBER SLEEVE
B91442420600,REPRODUCTION REAR SHIFT COVER 914-6
B91442422900,REAR SHIFT COVER 70-72 914-4
B91442429700,FRONT SHIFT COVER BOOT; 914 1970-72
B91442434302,SHIFT GUIDE PLATE 73-76
B91442450200,FRONT SHIFT COVER BAND (COVERBAND) 914 1970-76
B91450100010,DOOR SILL TRIANGLE 914
B91450101010,LONGITUDINAL MEMBER INNER RIGHT FRAME REPAIR 2-PIECE KIT
B91450101310,INNER ROCKER PANEL; LEFT SIDE; 914 1970-76
B91450101410,INNER ROCKER PANEL; RIGHT; 914 1970-76
B91450103010,REAR TRUNK HINGE CUP PIVOT BRACKET; 914
B91450104411,RIGHT REAR SUSPENSION CONSOLE
B91450107310GRV,BATTERY TRAY SUPPORT; 914 1970-76
B91450107510,EMERGENCY PARKING BRAKE PIVOT STAND
B91450108320,REAR TRUNK FLOOR
B91450108910,SILL THRESHOLD PLATE; LEFT
B91450109010,SILL THRESHOLD PLATE; RIGHT
B91450110910,CROSS MEMBER REPAIR; 914 LEFT
B91450111010,CROSS MEMBER REPAIR; 914 RIGHT
B91450111920,OUTER FIREWALL
B91450111920A,OUTER DRIVERS FIREWALL
B91450111920B,OUTER PASSENGER FIREWALL
B91450115010A,JACK POST AND SUPPORT COMBINATION; 914
B91450115110,JACK SUPPORT PLATE; 914
B91450115310,JACK POST TUBE; 914
B91450143410,LONGITUDINAL MEMBER INNER RIGHT FRAME REPAIR 2-PIECE KIT
B91450143410A,LONGITUDINAL MEMBER INNER RIGHT FRAME REPAIR REAR PIECE
B91450143410B,LONGITUDINAL MEMBER INNER RIGHT FRAME REPAIR FRONT LOWER PIECE
B91450143612,ENGINE SHELF; 914 1970-76
B91450158710,BATTERY TRAY; 914 1970-76
B91450164315,INNER FIREWALL LEFT DRIVER SIDE
B91450164315S,INNER FIREWALL SET LEFT AND RIGHT; SAVE $20.90
B91450164415,INNER FIREWALL RIGHT PASSENGER SIDE
B91450182510,ENGINE BAY SEAL CHANNEL PASS OR DRIVER
B914501937LR,FLOOR PAN QUARTER SECTION LEFT REAR; 914 1970-76
B914501937PC,PEDAL CLUSTER REINFORCEMENT; 914
B914501937RR,FLOOR PAN QUARTER SECTION RIGHT REAR; 914 1970-76
B91450194300,FLOOR PAN HINGE REINFORCEMENT (EA)
B91450194420A,UPPER WHEELHOUSE; RIGHT
B91450194420C,LOWER AND UPPER WHEELHOUSE (ONE PIECE); RIGHT; 914 1970-76
B91450302310,FRONT BUMPER PAD IMPACT STRIP - AKA BUMPER TOP SEAL
B91450302310S,FRONT AND REAR BUMPER PAD IMPACT STRIP SET; SAVE $76.05; SAVE $76.05
B91450302710,REAR BUMPER PAD IMPACT STRIP AKA BUMPER TOP SEAL
B914503125,ROCKER PANEL INSTALLATION KIT - 2 REQUIRED
B91450312510,OUTER ROCKER PANEL LEFT STEEL; 914
B914503125610,OUTER STEEL ROCKER PANELS; RIGHT AND LEFT SET OF TWO; 914 1970-76
B91450312610,OUTER ROCKER PANEL RIGHT STEEL; 914 1970-76
B91450323510,SPECIAL EDITION FRONT FIBERGLASS SPOILER
B91450390310DJ,DOOR JAMB REPAIR PANEL LEFT
B
B914503903DC,DOOR CATCH REINFORCEMENT
B91450390410DJ,DOOR JAMB REPAIR PANEL RIGHT
B914503908GT,REPRODUCTION 914 GT STEEL FENDER FLARES SET OF FOUR; 914 1970-76
B91450394310,REAR SAIL PANEL LEFT
B91450394410,REAR SAIL PANEL RIGHT
B91450410510,ENGINE GRILLE TO LID WELTING
B91450410710,GRILL TO BODY SEAL LEFT
B91450410810,GRILL TO BODY SEAL RIGHT
B91450411710,REAR ENGINE BAY SHROUD SEAL
B91450415510,ENGINE BAY SHROUD SEAL - LEFT OR RIGHT
B91450415510F,ENGINE BAY SHROUD SEAL - FRONT
B91450506310,BUMPER HORN LEFT FRONT 73-74 914
B91450506410,BUMPER BUFFER RIGHT FRONT
B91450592010GRV,REAR BUMPER CHROME; 914 1970-73
B91450704110,REAR FLOORPAN TRIANGLE LEFT 914 1970-76
B914507041AA,JACKING DONUT
B91450704210,REAR FLOORPAN TRIANGLE RIGHT 914 1970-76
B91451100000,FRONT TRUNK CARPET KIT TWO PIECE
B91451105200,EXTRA STRENGTH NYLON TRUNK LOCK CAM; 914
B91451190110,FRONT TRUNK HOOD SEAL
B91451190210,FRONT BULKHEAD SEAL; 914 1970-76
B91451202200,ENGINE LID DRIP PAN HARDWARE KIT; 914
B91451204110PVP,TRUNK LATCH SPRING PERCH INSERT
B91451217710,ENGINE LID RELEASE CABLE STAND
B91451219110,TRUNK HINGE BOLT
B91451219310,REAR TRUNK LOCK SEAL
B91451221510,REAR TRUNK HINGE STRAP
B91451231510,REAR TRUNK SEAL FRONT; 914 1970-76
B91451231710,REAR TRUNK SEAL
B91451231710S,REAR TRUNK SEAL SET; 5% OFF!
B91451231910,REAR LID TO GLASS SEAL
B91452101012B,LEFT OR RIGHT BOLSTER COVER 1972-76
B91452101014A,LEFT OR RIGHT SEAT BACKREST; 914 1975-76
B91452102910,SEAT ADJUSTER LOOP
B91452103509,SEAT CUSHION LEFT; 914 1970
B91452103510,CUSHION RECOVERING KIT LEFT; 914 1971
B91452103512,LEFT OR RIGHT SEAT CUSHION RECOVERING KIT; 1972-74 914
B91452103514,LEFT/RIGHT SEAT CUSHION RE-COVER KIT 1975-76
B91452105309,BLACK CENTER CUSHION
B91452105311,CENTER SEAT CUSHION REPRODUCTION; 914 1970-76
B91452106112A,LEFT OR RIGHT SEAT BACKREST; 914 1972-74
B91452107509,SEAT CUSHION RIGHT; 914 1970
B91452107510,SEAT CUSHION 1971 RIGHT
B91452124910,PLASTIC KNOB
B91452130371,REPLICA GT BUCKET SPORT SEAT
B91452133312,CUSHION RECOVER KIT 1972-74 914
B91452133314,CUSHION RE-COVER KIT 1975-76
B91452155600,CONSOLE BOX TOP RECOVERING KIT CENTER CUSHION
B91453114310,LEFT ROLLBAR SIDE SEAL
B91453114410,RIGHT ROLLBAR SIDE SEAL
B91453118510,LEFT TARGA TOP SIDE SEAL
B91453118610,RIGHT TARGA TOP SIDE SEAL
B91453181310,LEFT OUTER DOOR SEAL (ON DOOR)
B91453181410,RIGHT OUTER DOOR SEAL (ON DOOR)
B91453182110,LEFT INNER DOOR SEAL (ON BODY)
B91453182110S,INNER DOOR SEAL SET; 5% OFF!
B91453182210,RIGHT INNER DOOR SEAL (ON BODY)
B91453187310,LEFT DOOR WINDOW SQUEEGEE
B91453187410,RIGHT DOOR WINDOW SQUEEGEE
B914531905B,CHROME DOOR LATCH BASE; left or right 914 1970-76
B914531905C,NYLON DOOR LATCH CAM
B91454211110,LEFT SIDE WINDOW REAR CAP 1970-72
B91454211210,RIGHT SIDE WINDOW REAR CAP 1970-72
B91454217310,LEFT SIDE WINDOW REAR CAP 1973-76
B91454217310S,LEFT AND RIGHT SIDE WINDOW REAR CAP SET 1973-76; 10% OFF!
B91454217410,RIGHT SIDE WINDOW REAR CAP 1973-76
B91455101510A,FOOT SUPPORT STRAP
B91455102912,FRONT TRUNK TIRE BOARD
B91455104010,REAR TRUNK CARPET 914 1970-71
B91455104011,REAR TRUNK CARPET; 914 1972-74
B91455104410,REAR TRUNK CARPET 914 1975-76
B91455106110,REPRODUCTION PEDAL BOARD
B91455107712700,DOMESTIC CHARCOAL LOOP CARPET KIT 914 (MADE TO ORDER)
B91455113711,FOOT STEP PROFILE THRESHOLD SILL AND CARPET STRIPS SET OF FOUR; 914
B91455113711S,FOOT STEP PROFILE THRESHOLD SILL AND CARPET STRIPS SET OF FOUR; 914
B91455117270,FLOORPAN FRAME CENTER TUNNEL VINYL SET 914 1970
B91455117271,FLOORPAN FRAME CENTER TUNNEL VINYL SET 914 1971
B91455117272,FLOORPAN FRAME CENTER TUNNEL VINYL SET 914 1972-76
B91455118711,LINING FOR FRONT TRUNK CROSSWALL FELT 914
B91455141911,BLACK ANODIZED COVERING FOOT STEP INNER OR CARPET STRIP SET
B91455150510, SPEAKER GRILLE ENCLOSURE SET 914
B914552010,DASH FACE MATERIAL; 914 914-6 1970-71
B914552011,DASH FACE MATERIAL; 914 1972-74
B914552012,DASH FACE MATERIAL; 914 1975-76
B91455202110,UPPER DASH FACE KIT ; 914
B91455203112,RECOVERED FACTORY DASH 914 1970-76
B91455203910A,DASHBOARD RADIO FACEPLATE; 914 1970-74
B91455203910B,DASHBOARD RADIO FACEPLATE; 914 1975-76
B91455204010BA,DASHBOARD RADIO FACE PLATE; 914 FOR BLAUPUNKT FRANKFURT AND BECKER RADIOS
B91455204010BB,DASHBOARD RADIO FACEPLATE; 914 FOR BLAUPUNKT FRANKFURT AND BECKER RADIOS
B914552040A2,DIN RADIO FACE PLATE 914 1970-74
B91455224110,STEERING COLUMN COVER 914-6
B91455226310,DASH TO WINDSHIELD BEAD; 914 1970-76
B91455244410,DIN FACEPLATE 914 1975-76
B91455501009A,1970 LEFT BACKREST
B91455501009B,1970 LEFT BOLSTER
B91455501010A,1971 BACKREST LEFT RECOVERING KIT
B91455501010B,1971 LEFT BOLSTER
B91455501709,RECOVERED DOOR PANEL LEFT SMOOTH PEBBLE GRAIN 914 1970
B91455501709C,RECOVERED DOOR PANEL LEFT PORSCHE CLOTH MATERIAL; 914 1970-76
B91455501809,RECOVERED DOOR PANEL RIGHT SMOOTH PEBBLE GRAIN 914 1970
B91455501810, DOOR PANEL RIGHT 914--1971
B91455502100,REPRODUCTION DRIVERS SIDE DEPOSIT BOX
B91455504310,END PIECE DOOR JAMB TRIM 914
B91455506109,BACK PAD RECOVERING KIT; 914 1970
B91455506110,BACK PAD RECOVERING KIT 914--1971
B91455506112,BACK PAD RECOVERING KIT; 914 1972-76
B91455508109A,BACKREST RIGHT; 914 1970
B91455508109B,1970 BOLSTER RIGHT
B91455508110A,1971 RIGHT BACKREST
B91455508110B,1971 RIGHT BOLSTER
B91455512910,LARGE INTERIOR PLUG
B91455528310,DOOR PANEL LEFT BRICK WEAVE; 914 1972-74
B91455528311,LEFT DOOR PANEL (BASKET WEAVE) 914--1975-76
B91455528410,DOOR PANEL RIGHT BRICK WEAVE; 914 1972-74
B91455528411,RIGHT DOOR PANEL (BASKET WEAVE) 914--1975-76
B91455600310,REAR TRUNK INSULATOR PAD 914 1973-76
B914556110KT,CUSTOM CUT FLOOR PAN TAR KIT 6 PIECES
B91455611510,LINING REAR LEFT; 914
B91455611611,LINING REAR RIGHT 1972-76
B91455612811,SOUND ABSORBER REAR CENTER TUNNEL FOR PORSCHE 914
B91455613510,ENGINE INSULATOR PAD
B91455627110E,REAR HEAT INSULATION LINING 914 70-72
B91455901110,ROLL BAR CHROME CLIP
B91455911210,VW EUROPEAN EMBLEM GOLD 914-6
B91455911410,GOLD 914-6 EMBLEM
B91455912011,EMBLEM-2.0
B91455912711,DISTANCE WASHER 914 VALANCES ROCKER PANELS AND SPOILERS
B91455915510,FENDER TO COWL SEAL
B91455916310,TRIM FLOOR PAN DEFLECTOR
B91455921910,REPRODUCTION COVER SEAL BRACKET
B91455922510,DISTANCE PIECE 914
B91455924310,ENGINE SHELF PLUG 914-6
B91455924510,ENGINE SHELF PLUG
B91455925210,FRONT RUBBER PANEL PLUG 914
B91455926010,HORN GRILL W/O HOLE PRIMED
B91455928710,EMBLEM 914 GOLD
B91455928711,EMBLEM BLACK METAL WITH TWO MOUNTING PEGS
B91455929311,2.0 EMBLEM DECAL SELF-ADHESIVE VINYL
B91455940210RA,REPRODUCTION 914 CENTER CONSOLE WITH HOLES FOR AFTERMARKET GAUGES
B91455940210RP,REPRODUCTION 914 CENTER CONSOLE WITH HOLES FOR FACTORY GAUGES
B914559KIT,DRIVING FOG LIGHT GRILLE SCREW AND CLIP KIT; 914
B91456303910,WINDSHIELD TOP SEAL
B91456307110,TOP RELEASE PLASTIC LATCH HANDLE ONLY
B91456307711,TARGA TOP REAR SEAL
B91456308111,ROOF LATCH HOOK ONLY DRIVERS LEFT SIDE
B91456308211,TOP LATCH HOOK ONLY
B91456331910,FRONT TARGA TOP SEAL
B91457112910,AIR BOX SEAL; 914 1973-76
B91457190410, AIRBOX FRAME SEAL; 914 1970-73
B91460201100,CONTROL UNIT BRACKET 914-6
B91461010700,RELAY BOARD CLIP
B91461011013,REPRODUCTION RELAY BOARD COVER 1973-76
B91461011111,RELAY BOARD COVER 1970-72
B91461011113,RELAY PANEL COVER REPRODUCTION
B91461123310,BATTERY CLAMP AND BOLT
B91461215110,CENTER CONSOLE WIRING HARNESS
B91461316300,IGNITION SWITCH BEZEL 914-6
B91461331100,STEERING COLUMN COVER 914-6
B91461349100,BOOT FOR REVERSE LIGHT SWITCH AND MASTER CYLINDER
B91461801310,CONTROL UNIT BRACKET
B91463121810,MARKER LIGHT CAP
B91463140500,LEFT 914 SIDEMARKER ASSEMBLY
B91463140506,FRONT SIDE MARKER SEAL
B914631405A,FRONT SIDE MARKER BASE L OR R
B91463160100,AUATL LICENSE LIGHT - 2 REQUIRED PER CAR.
B91463191311,REPRODUCTION 914 FACTORY DRIVING LIGHT GLASS LENS EACH
B91463193900,TAIL LIGHT LENSE SEAL PAIR
B91463193911,RED USA TAILLIGHT LENS LEFT
B91463193940,USA RED TAILLIGHT LENS; SET OF TWO
B91463194011,USA RED TAILLIGHT LENS RIGHT
B91463194500,AMBER SIDE MARKER LENS LEFT
B91463194600,AMBER SIDE MARKER LENS RIGHT
B91463194910,EUROPEAN TAILLIGHT LENS LEFT
B91463194911,CLEAR ITALIAN TAILLIGHT LENS LEFT
B91463195010,EUROPEAN TAILLIGHT LENS RIGHT
B91463195011,CLEAR ITALIAN TAILLIGHT LENS RIGHT
B91463195110,TAILLIGHT LENS EUROPEAN AMBER/RED SET OF TWO; 914 1970-76
B91463195710,FRONT TURN SIGNAL SEAL
B91463195810,SCREW 4X17 914 SIDE MARKER OR TURN SIGNAL LENS
B91463196010,TAILLIGHT LENS ITALIAN CLEAR SET OF TWO; 914 1970-76
B9147076KIT,650 PIECE BODY HARDWARE KIT
B91472202110,STRAP FOR JACK
B914731039B,SIDE MIRROR GASKET 5 1/4 INCH
B914731039C,SIDE MIRROR GASKET 5 INCH
B91473111610,MIRROR BASE SEAL
B91473132710,CENTER VISOR MOUNT CLIP
B91473193910,REPLACEMENT EXTERIOR MIRROR GLASS 5 1/4 INCH
B91473194010,REPLACEMENT EXTERIOR MIRROR GLASS 5 INCH
B914803183A,PRESS STICKERS / LABELS FOR SEAT BELT RECEIVER
B914837227B,LOCK CYLINDER GASKET
B91495501710,RECOVERED DOOR PANEL LEFT SMOOTH; 914 1971
B914ENGROMKIT,ENGINE SHEETMETAL TIN GROMMET KIT
B914WRB,DRIVER WINDOW REGULATOR BUTTON
B92311035802,CONNECTING INTAKE BOOT HOSE 912
B93150537104,FRONT POLY SPOILER; 944 1983-91
B94462830500,WIPER ARM CAP
B94473103502,SIDE MIRROR GLASS (GLASS ONLY); 944 1983-91
B96461362100S,POWER WINDOW SWITCH SET ; 5% OFF!
B96473131940,LEFT OUTER VISOR PIVOT CAB LEFT; 914 (1970-76) 944 964 911 WITHOUT PIN
B96473132040,RIGHT OUTER VISOR PIVOT 1970-76 914 964 CAB 911 CAB WITHOUT PIN
B99350133500GRV,LEFT INNER ROCKER PANEL
B99350133600GRV,RIGHT INNER ROCKER PANEL
B99953200100,SHIFT KNOB CRUSH SLEEVE
B99970209150,RUBBER GROMMET FOR ENGINE DRIP PAN FUNNEL
BAA500,RUBBER SEAL KIT - 914; SAVE $69.63
BAA500A,COMPLETE DELUXE RUBBER SEAL KIT - 914; SAVE $81.53
BAA52138300,GT SPORT SEAT 914-6
BAA541,FRONT WINDSHIELD INSTALLATION KIT; 914
BAA542,REAR WINDOW INSTALLATION KIT; 914 1970-76
BAA555,DOOR PANEL HARDWARE INSTALL KIT; 914 1970-74
BAA556,DOOR PANEL HARDWARE KIT; 914 1975-76
BAAA006701700,DOOR JAMB STICKER DECAL; 914-6 1970-71
BAAA0067200,1970--1972 914 DOOR JAMB STICKER DECAL
BAAA0067300,DOOR JAMB STICKER DECAL; 914 1973-76
BAAA133000,UPPER FUEL LINE KIT
BAAA20100074,FUEL LINE KIT 914 1970-74
BAAA20100076,FUEL LINE KIT 914 1975-76
BAAVACKIT1,VACUUM LINE KIT 1.7
BAAVACKIT2,VACUUM LINE KIT 1.8L
BAAVACKIT3,VACUUM LINE KIT 73-74 2.0
BAAVACKIT4,VACUUM LINE KIT 1975 1.8
BAAVACKIT5,VACUUM LINE KIT 75-76 2.0
BFUCHSTSH,FUCHS WHEEL T-SHIRT SMALL
BMIS2000,FIVE LUG CONVERSION KIT 914
BMIS400,HEATER BLOWER UPDATE KIT; 914 1970-76
BN160600,AIR CLEANER WINGNUT; 914 1.7
BPCG42450100,FRONT SHIFT COVER
BPCG42450101,REAR SHIFT COVER; 914 1973-76
BPCG53160100,LARGE DOOR HANDLE SEAL
BPCG5316010S,4-PIECE DOOR HANDLE SEAL SET 914; 5% OFF!
BPCG53160300,SMALL DOOR HANDLE SEAL
BPCG72210710,REAR BUMPER TOW EYE PLUG CHROME
BPNA55990100,ENGINE GRILL (LID) LETTERING KIT SET "PORSCHE" CHROME / SILVER FOR 914
BPQTSHIRT,PORSCHE QUOTES T-SHIRT
BRAC1025B,TWO SYLLABLE T-SHIRT BLACK
BRAC1025W,TWO SYLLABLE T-SHIRT WHITE
BRAC2068B,TWO SYLLABLE SWEATSHIRT BLACK
BRAC2068W,TWO SYLLABLE SWEATSHIRT WHITE
BSHTAUTOB,AUTOBAHN LOGO SHIRT
BSHTFERD,FERDINAND PORSCHE T-SHIRT
BSHTLATL,LIVING AT THE LIMIT T-SHIRT
BTC1001,AIR CONDITIONING KIT INSTRUCTIONS; 914
BTC1003,BATTERY MAINTENANCE PROCEDURE
BTC1005,STARTING CIRCUIT DIAGNOSIS GUIDE
BTC1006,CLUTCH INSTALLATION MANUAL; 914
BTC1007,CLUTCH REPLACEMENT PROCEDURE
BTC1008,CLUTCH TUBE REPAIR PROCEDURE
BTC1011,DOOR GLASS ADJUSTMENT AND MAINTENENCE 1970-73; 914
BTC1012,ELECTRIC WIRING DIAGRAM; 914
BTC1013,HOW TO CONVERT YOUR 914-4 TO A 914-6; CONVERSION GUIDE
BTC1014,2.0 ENGINE REBUILD TIPS
BTC1015,NON STARTNG FUEL INJECTION TROUBLESHOOTING PROCEDURE
BTC1016,FUEL INJECTION OPERATION GUIDE
BTC1017,FUEL PUMP RELOCATION GUIDE
BTC1018,HOW TO BUY A PORSCHE; 914 1970-76
BTC1019,OIL COOLER SEAL REPLACEMENT GUIDE
BTC1020,OIL GALLEY PLUG REPLACEMENT GUIDE
BTC1021,POWERPLANT REMOVAL AND INSTALLATION GUIDE
BTC1022,PUSH ROD TUBE SEAL REPLACEMENT GUIDE
BTC1023,REAR BRAKE CALIPER REBUILD PROCEDURE
BTC1024,REAR WINDOW RESEAL PROCEDURE
BTC1025,ROTISSERIE BUILDING INSTRUCTIONS (PLANS); 914 1970-76
BTC1027,SEAT ADJUSTER LOOP REPLACEMENT GUIDE
BTC1028,STORAGE TIPS AND PROCEDURE GUIDE
BTC1034,TRUNK HINGE CUP REPLACEMENT PROCEDURE
BTC1040,VALVE ADJUST PROCEDURE GUIDE
BTC1041,WINDSHIELD REPLACEMENT GUIDE
BTC1042,9014 INFORMATION KIT; 914 1970-76
BTC1043,DETAILING PROCEDURE
rbk7074 914 tech tips 700
rbk7075 924 944 tech tips
rzp9240 924 rear lens update kit
rzp9440 944 rear lens update kit
rzp9441 turbo rear lens update kit
rzp9242 PORSCHE 924 or 944 rear lens update kit
rzp914 914 rear lens update kit with electric release
rmit1409 front fiberglass bumper
rmit1432 914 abs rocker panel set
