burningman
Apr 9 2016, 08:54 PM
Hey all, I'm about to lay some soundproofing I the doors with raaamat soundproofing, the standard sticky backed stuff. The question I have is how did you apply it to the horizontal structural ribs in the door? Did you skip them altogether, cut thin strips to lay within them or did you lay a large solid piece of soundproofing and carefully adhere it to the peaks and valleys of the ribs?
Hopefully this makes sense, thanks for your help.
Chris914n6
Apr 9 2016, 10:03 PM
Skip it, it doesn't vibrate.
Also, it doesn't take a lot of mat to be effective. Trick is to bang on stuff and listen, if it's not low pitch stick it.
Sedonut
Apr 9 2016, 10:15 PM
Make sure the inside of the door is really clean and what ever soundproofing sticks well. With the sun beating on your door and a vertical surface the adhesive may let go. Then you have a nice heavy piece of mat to interfere with your window.
If it were me I would pass on doing the doors.
Tbrown4x4
Apr 10 2016, 03:47 AM
QUOTE(Sedonut @ Apr 9 2016, 09:15 PM)
Sun? In Seattle?
saigon71
Apr 10 2016, 07:25 AM
I skipped the doors. For application on challenging areas with a lot of curves and such, I cut strips - much easier to work with.
dflesburg
Apr 10 2016, 07:40 AM
we put it on the inside of the door cards, works well there. (its a secret so don't tell.)
dflesburg
Apr 10 2016, 07:41 AM
we also put it on the underside of the floor mat carpets so that it doesn't trap water there.
Jason74914
Apr 10 2016, 07:47 AM
I would go with just as much as you need. If you are using Dynamat, that stuff is heavy and weight can add up.
burningman
Apr 10 2016, 08:25 AM
Cool thanks for your help everyone. I've done a bunch of soundproofing before but those ribbed structural supports threw me for a loop I'll just skip them.
Cairo94507
Apr 10 2016, 10:43 AM
I have installed stuff very similar to Dynamat in other cars and I installed it on the inside of the door skin. I used strips that were very manageable. I just made sure there was no dirt/dust on the inside of the actual door skin and placed it and then used a small roller to lay it flat and make sure there were no bubbles.
Years later when working on the door I tried to peel back a piece and that stuff was adhered very well. This is in CA so no real cold but some pretty hot days. I believe Scotty will be adding the same material to the inner door skins of my Six. As others have said, you do not need to have 100% coverage of the skin to have the desire effect.
The secret is to take your time and work with smaller pieces. I spent a week doing the interior of a car in the evenings. One section at a time and then stop for the day.
Tom_T
Apr 10 2016, 04:52 PM
.... & rust free - or treat, prime & paint before soundproofing!
Skip the reinforcement bars - they're just there for side impact protection.
Tom
