Not directly 914. My son wants to megasquirt a lotus 907 motor and put it in his MGB. He will use 4 independent motorcycle throttle bodies. Whether that will work is not the point of the post. He is making manifolds that match both outlines. Oval at the ports, and round at the throttles. Here we go. Don't try this at home it isn't safe.
Here is the flower pot furnace - literally. Air is temporaily going in the top cause I had a crucible failure plugging the bottom stainless pipe air inlet. Air from a water heater exhaust fan.
It works
Melted fast and sent Doug scrambling to mold. Cores were pre made tho
No one was there to film the pour but here it is
I singed my beard. Had to cut it short that day next day to travel by air to be a biologist for work
And here it is
Note it had cleared up. The first cast did not go -air/steam trapped- so this is the following weekend when it wasn't snowing! The water on the pavement is a hazard btw. So it was safer round 2.
One thing that made it work was using quality aluminum -old 1.7 pistons that would never push again. Now we know where they are and the shell that carried them will be my 3.2. So life goes on.
Again - Doug is a mechanical engineer and I have cast metal as a hobby for 40 years. We cast about 10 lbs of Alu; enough metal to burn your arm off. I singed my beard cause it is long enough to blow in a light breeze, but even that was stupid. We always handled the crucible with tools that kept us at a distance and we have practiced dropping valuable things to save your ass. Better a crushed engine than a crushed leg sort of thing. Still...
