Hi--
I've have a -6 oil cooler that I'm trying to return to service. The cooler came out of a running car and although the outside is dirty, it shows no sign of damage, oil leaks or of an engine making metal. With a somewhat clean bill of health, the next step was to remove the oil-line to cooler fastener nut. But before I started, I search World and talked to forum members who have had success removing the nut. Following their leads, I bought a 32 mm open end wrench and had it thinned by a machinist to ~ .330" (to fit the space available).
After soaking the nut with Kroil for several days I attempted to use the modified open-end and a 36 mm box-end wrench to loosen the nut. The oil-line nut didn’t come close to moving. I also tried an industrial strength heat gun to heat the nut. Again, even with the heat, it remained locked in place. Based on my "feel" for the amount of torque I was applying, I was afraid that I would ruin the cooler. At that point the oil-line, already cut off, and the threaded fastener and nut became totally sacrificial. Using a Dremel tool, I slit the oil-line fitting on both sides and cracked it open enough that it broke away. I expected the fitting was swaged on but was surprised to find that fitting is threading, suggesting that you might be able to unscrew it and saving it for future use.
Removing the oil-line opened up the oil-line side of the fastener nut which was still attached to the cooler. I tried soaking both sides with Kroil again for a couple of days but removal was still a no go. Again using the Dermal tool, I slit and broke away the back side of the nut, working the Dremel from flat to flat. I used a flat blade screw driver to pry the slit sections of the nut away, when I finished, the entire back of the nut was removed. Note: Looking into the oil-line seal area gives you a good idea how much of the back of the nut you can safely remove while staying away from the sealing surface of the threaded cooler connection. With the nut removed the internal seal/ barbed fitting of the oil-line lifted away and the remainder of the nut turned off by hand. A quick look at the photos should take you the rest of the way.
The next step is to pressure test the cooler. I’ve seen a couple of photos testers but don’t know where they can be purchased. Does anybody have a tester they can lend me or know where I can buy one?
Any questions, let me know.
--Papermaker
