QUOTE(SirAndy @ Apr 15 2016, 08:46 PM)
Why did my 914 become less safe when the distance from the rollbar to my head is no closer than the distance from the door-frame on my Jetta to my head?
I didn't say that Andy, you did. Re-read the first post. The discussion was about wisdom of adding a bar or cage to a street car, in other words modifying the SAME car, before and after. I have no idea about Jettas, but wasn't your Jetta designed by an engineer specifically for passenger survivability? Different seats and belts? Cabin crush differently? More and different pladding inside, all different materials? Have airbags? In fact EVERYTHING about the car acting differently in a crash? It's not as simple as clearance distance, your question is about apples to oranges, and the answer is 'who knows?' Which is why the discussion was about putting a roll bar into a street car and not why Jettas are safer than 914's. That's a totally different discussion.
I am profoundly confused by your logic.
You fully accept the margin of hazard in my Jetta but when i add something to my 914 that brings me within the same margin of hazard, it's instagib brainmush unsafe at any speed.
Again, I never talked about Jettas. But by the same before/after logic if you did add a roll cage to your Jetta you're creating exactly the same situation
with your Jetta, by reducing clearances. More hazard than a 914? I don't know, can't know, you'd need to talk to someone else about that. But more hazzard in the Jetta with the cage than without? Before and after? Yes, the same logic applies, and worse, if you block the Jetta's airbags.
My point has been that with that modification you're reducing clearances in THAT car, be it 914 or Jetta, which, by itself, makes THAT car less safe, before and after. In a race car you have a race seat, restricting movement, race belts, restricting movement, and a helmet, for exactly the type of impact described in the first post. If you add all those things to the street car along with the bar/cage then yes, safer. Without them the bar/cage adds a new safety hazard to
the same car.I didn't invent any of this, you know it all already because it's conventional wisdom. So is conventional wisdom incorrect? How is that?
