1975 2.0 with appearance group
bought 6 years ago, $2000
- it was not running but would fire if we sprayed starter into intake(D-jet)
- bought from a marine in north Carolina that left it sitting out for a year while on deployment. it had all original interior except someone took out the center console and took out the fog lights, even though as an appearance group car it would have had both.
- I knew nothing about 914s at the time and did not know where to look for rust but the panels were solid with no dents no rust so we pushed it onto the trailer and away I went. 6 hours home.
-what it took to get started- pulled the tank got the d-jet manual, replaced all the fuel lines and tank seals, injector seals fuel filter and pump. spent about $500 and another $250 for a rebuilt MPS- the MPS was shot, had water in it from being mounted upside down, and once put back together, we added gass and it fired right up!!!! high idle, MPS was set too lean and had vac leaks but that all was taken care of . -
- since then I ve spent about $5k on it, completely redone interior, Dr evil trans, cv, all bushings, bearings seals shocks struts brake lines master cylinder, clutch pressure plate and flywheel, rear main seal, push rod tube seals etc etc. , stearing rack turbo tie rods, and ball joints 5 lug conversion and all new 16" fuchs""
- next up it is going to Connecticut to get rust repain in longs done, fenders fixed and stretched out and prepped for repaint- with a 2056 motor rebuild.
Car has had 5 owners and started out in Dublin, Ohio. Went to California, 29 palms, to Camp legeune and now SC . it has 148k miles on it , motor has never ebee rebuilt
posting of the fixes will go to my build challenge thread - next month is a road trip to drop the car off at Racer Chris's shop
