QUOTE(McMark @ Apr 16 2016, 04:24 AM)
But unstitched is another drain on the battery when parked. I've got a tiny, minuscule power usage bluetooth setup in my car and it will suck the battery dry if I don't drive it for a week.
I vote switched.
I had an LED going all winter without trouble, but an Ipad is another thing entirely. When the battery is low it really sucks the juice. I know because I put together a simple voltage regulator to charge them and it sure heated up the Alu heat sink at first, but as the battery topped off it was cool. The real issue is how you plan to use it. If you want to have the iPad charged all the time for a few days or weeks I doubt that one charge would be a problem for the car battery - it didn't trouble my little lawn mower lead acid battery. On the other hand if the thing is plugged in for months without attention, then it would be a possible drain. I think at top the pad drains about 500 mA. Then it would be close to nil when charged. If just sleeping the iPad is keeping track of internet blue tooth etc and that takes power. Of course you can turn those off or you can shut the device down and leave it on the wire.
