QUOTE(mark04usa @ Apr 17 2016, 04:01 AM)
QUOTE(jkonzelman @ Apr 16 2016, 08:21 PM)
so i recently did the flywheel resurface and new clutch, and went to install a shim under the pivot for the shift fork. HOW THE HECK CAN YOU REMOVE THAT DARN THING? its recessed down in the tranny case wall in a circular cutout, and there is not enough room to get any tool that I own between the pivot base and the hole its in.
any help?
QUOTE(Cap'n Krusty @ Jan 27 2014, 11:00 AM) *
Snap On "FMS14". It's a 14mm semi-deep 12 point chrome socket. Fits perfectly.
Harbour frieght cheapo or used 14mm deep socket and a grinder mod.
QUOTE(jack20 @ Apr 16 2016, 09:06 PM)
Thanks Mark but could you elaborate?
Thanks,
Jack
The 914 flywheel is a two step grind. the friction surface and the pressure plate mounting surface must both be ground the equal amount.
Two step costs a bit more, the majority of flywheels (including many 911) are flat no step grinds.
Your machine shop will know this,
