Cuda911
Apr 18 2016, 12:04 AM
Spent all day driving down the coast. Stopped a bunch of places. All day long, the car ran perfectly.
Then stopped for a couple hours for dinner. When I started it up, it ran fine, but then stalled out at the first traffic light when I let up on the gas. This happened a few more times. When running, it would buck like a bronco. Heel-toed it at every light to keep it from stalling. Got on the freeway, and it was still bucking. But, after about 5 or 10 miles, everything went back to running fine.
So, what's up with that? What should I be looking for to prevent this in the future?
'74, 1.8, FI.
Thanks!
JeffBowlsby
Apr 18 2016, 07:40 AM
Oil the advance weights lately? 1 drop 30 wt in the center of dizzy shaft every year.
dangrouche
Apr 18 2016, 07:45 AM
Heat soak on fuel pump? . Is pump in factory location? Dirty fuel tank? I had a 911 that drove well but once the dirt stacked up on the fuel fiter it sputtered. Shut it off. Then restarted and ran well.
boxsterfan
Apr 18 2016, 09:05 AM
Shorting of the seatbelt interlock relay under the passenger seat?
AZ914
Apr 18 2016, 12:44 PM
I had the 'stop-light-stall' problem back when I was still running with points... just a thought.
jor
Apr 18 2016, 03:13 PM
QUOTE(AZ914 @ Apr 18 2016, 11:44 AM)
It sounds like points to me.
Cuda911
Apr 18 2016, 03:45 PM
Thanks, all. The points is is were supposedly replaced when I bought the car, but I have since found that a number of items, for which there were paid invoices, were not actually done by the mechanic that billed for the work.
I did have the seat belt interlock bypassed, so that's a good place to check too.
Fuel pump is in stock location. It has a pretty new fuel filter, but that's sure easy and cheap to replace. Nope, I have never oiled the dizzy shaft, so another cheap and simple thing I can try.
Thanks, all!
TheCabinetmaker
Apr 18 2016, 05:53 PM
Points will not go wonky then go back to normal. When the dwell degrades it stays that way till points are closed and will no longer run. A bad coil will cause those problems, as will a failing condenser.
