Teknon
Mar 30 2005, 07:50 PM
Just as the throttle plate opens all the way the two linkages touch. I'm thinking it should be a smooth throw and not hop when it touchs together. It gets some resistance as it goes to open all the way.
http://www.d2maso.com/P1010025.MOV
Dave_Darling
Mar 30 2005, 08:53 PM
Umm, I'm not quite exactly sure what you mean, but...
The throttle should open smoothly all the way. The mid-73+ throttle body (the kind in your movie) has the extra spring on it just in case the first breaks. I believe that it should pretty much just sit there while the main linkage, the one with the long skinny coil spring that hooks to a bracket on the manifold, does the work.
--DD
Teknon
Mar 30 2005, 11:16 PM
It wasn't opening in smoothly. It hung up like 4/5 the way up to full. Since you said it should open smoothly with no bind. I sanded a tad of the metal tab and now it has a smooth motion. Thanks again Dave
