JPA914
Apr 21 2016, 07:15 PM
Maybe a silly question, but after removing my air cleaner I noticed that my throttle body doesn't open fully. By "fully" I mean the plate being in a straight up, vertical position. Mine opens to a max of about 30 degrees less than this. Keep in mind, this is while manipulating the throttle at the engine, so it's not a pedal issue.
Is this normal position for WOT?
larryM
Apr 21 2016, 07:27 PM
you are correct - vertical is full open -
awful performance is the result of your current condition
JPA914
Apr 21 2016, 07:34 PM
Thanks, I'll have to figure out what's hanging it up then.
JPA914
Apr 21 2016, 08:04 PM
QUOTE(r_towle @ Apr 21 2016, 08:41 PM)
Throttle position switch
Ah, didn't think of that. I'll check for sure.
