Hi Guys,
This weekend I re-installed the windshield and trim, using info from a bunch of the great threads on this site.
The PO set the windshield with way too much butyl and no trim...so it looked pretty gnarly. The glass was sitting too proud and low to just add trim, which is why I had to pull it out and reinstall.
I never installed a windshield before...but thanks to you guys it came out way better than expected and I thought I'd recap what I learned from this amazing community.
- Use piano wire to cut out the old butyl and remove the windshield
- Mineral spirits to clean up the butyl residue
- Chop off the old trim clips using a putty knife and hammer
- Dry-fit the windshield and use tape to mark the proper placement so it goes down right.
- Apply butyl primer before laying the butyl down
- Use 5/16 butyl bead
- Don't push too hard on the corners when setting the windshield
- The trim installs with a satisfying "snap" (totally!)
And here's one extra tip to add to the knowledge base... Buy a few extra trim clips. The stud can bend like a nail if you don't hit it just right.
Mark and his team at 914rubber.com produce gorgeous trim...and it arrived in perfect condition due to their careful packing. The dash pad and top are also from them.
Just wanted to say thanks and share some pics!
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
