Downunderman
Apr 26 2016, 01:12 PM
So I got it back from stripping last Friday. Photos follow. It was painted on Monday, but I don't have any decent photos yet as we finished in the dark.
Downunderman
Apr 26 2016, 01:17 PM
More.
Downunderman
Apr 26 2016, 01:19 PM
A few more.
914time
Apr 26 2016, 01:57 PM
Hey Howie! Looks like you found your project car finally and it's looking GOOD!
You should should clear primer it and leave it nekkid
r_towle
Apr 26 2016, 02:13 PM
Curious,
What did your painter do with all the flash rust?
Rich
Downunderman
Apr 26 2016, 02:21 PM
QUOTE(r_towle @ Apr 27 2016, 06:13 AM)
Curious,
Rich
We used this:
http://www.phoenixpaints.com.au/products/p.../metalfix-1000/ after a rub with a scotchbrite.
Ferg
Apr 26 2016, 02:24 PM
Curious about the drop floor pans? Did you do the Mod, how tall are you?
I've seen it on Pantera's but never a 914.
Downunderman
Apr 26 2016, 02:47 PM
Ferg,
I dropped the floors 35mm so that I could put seat runners under the race seats. Ultimately it will have to fit a somewhat tall grandson. Its being built for historic racing down here.
barrym
Apr 26 2016, 03:20 PM
looking good there chap !
porschetub
Apr 26 2016, 04:09 PM
Wow someones been busy with a welder
,was the car RH drive when you got it?.
Noticed the dropped floors expect you are tall with a rollgage going in?
Great work keep up the progress reports
Downunderman
Apr 26 2016, 05:45 PM
Thanks Barry.
It was LHD. I have an OBP pedal unit to bolt in.
Yes, lots of welding, plasma cutter, grinder, shear and folder.
914forme
Apr 26 2016, 06:14 PM
I would like to see the OBP pedal assembly, looks like it would solve a few issues.
Like this one?
Downunderman
Apr 26 2016, 07:06 PM
Pretty much exactly that. I had to narrow the chassis rail by about 20mm to make it fit and line up, then the cross member brace was re-located to the front in the boot floor with a bit of reinforcing and plating.
Dave_Darling
Apr 26 2016, 09:15 PM
I'm shocked to see such pornographic content on here! That poor 914 has been completely stripped naked, and you're just putting her out there for all to ogle!
--DD
PanelBilly
Apr 26 2016, 09:58 PM
QUOTE(Dave_Darling @ Apr 26 2016, 08:15 PM)
--DD
But no pink has been shown, so its ok
rick 918-S
Apr 26 2016, 10:05 PM
Very nice!
(Fosters)
Downunderman
Apr 26 2016, 10:15 PM
It was rendered naked by these people: www.redistrip.com.au
sixnotfour
Apr 27 2016, 01:13 AM
Looks great !!
I am curious if they skipped a step or why does it have so much new rust ??
I read this from the link
Depending on the anti-rust coating you have chosen A protective residual film remains on all surfaces
I then read this ,,
And after processing:
We can apply phosphate treatment and rust preventative oils to all the cleaned surfaces
was this an extra cost option ??
Downunderman
Apr 27 2016, 02:03 AM
The rust looks much worse than it really was. I didn't go wiith the protective coating because it didn't work with the paint. Yes it was an extra cost option, but not necessary. I left it in the shed on Saturday and Sunday with a dehumidifier pumping and it didn't rust much at all.
sixnotfour
Apr 27 2016, 10:34 AM
barrym
May 1 2016, 02:33 AM
I'm just about to start on the pedal box area , you may recall the pedal box I Have? I need to do the same as you have, but notice the tie mount for the suspension cross bar you have cut off - Whats your plan for this area ??
Downunderman
May 1 2016, 12:32 PM
After tossing around all sorts of options which were inelegant, I cut the brace off the cross member and turned it 180 deg and mounted the bobbin through the back end of the boot floor. You can just see it in a couple of the front boot photos. I plated the area before I mounted the bobbin. On balance the simplest and easiest.
barrym
May 1 2016, 03:59 PM
Ahhhhh- nice .... I shall investigate ...
Thx
nihil44
May 1 2016, 09:12 PM
Howard,
Am I not paying attention or is there no seam sealer left?
If none, did you remove it first or did the stripping process do it?
David
Downunderman
May 2 2016, 12:45 AM
David,
The stripping process got rid of all the seam sealer, but for a few spots which I dug out as best I could, but it got 98% of it. I think it was in the tank frothing and bubbling for 2 - 3 weeks.
