Mikey914
Apr 28 2016, 12:44 AM
Just finished the fuel line grommets for the fire wall area. Both are done, but I have a few other items that are done that I want to put up too so it may be a day or two as we wrap these up.
$4 a pop
I'm going stainless on my lines and will do 10mm for both, but figures there would be those that wanted the correct ones for the OEM application.
I have test fitted these on my Cary's car and they are a nice fit. The material is silicone so that it will make a great seal and are just slightly softer than the OEM to make them easier to install.
So let me know who's up for some?
marksteinhilber
Apr 28 2016, 11:07 AM
QUOTE(Mikey914 @ Apr 27 2016, 11:44 PM)
$4 a pop
I'm ready for some. I guess I'll need two of the 10mm and two of the 8mm for my project car. How soon will they be made? Tell me what I need to do to order and pay. Mark S.
BillC
Apr 28 2016, 11:34 AM
Good timing, I'm almost ready to install my new stainless fuel lines. So, I'll need a set too. How many are needed? One of each or two of each?
914_tinker
Apr 28 2016, 02:39 PM
I'll take a set. Thanks
Mikey914
Apr 28 2016, 02:55 PM
QUOTE(BillC @ Apr 28 2016, 10:34 AM)
One of each, but verify your tube size. I'm using 10mm for both of mine as it's easier.
ThinAir
Apr 28 2016, 05:18 PM
How about the oval grommets for passing the fuel hoses through sheet metal under the battery tray?
Silver Surfer
Apr 28 2016, 05:25 PM
I'll take a 10mm set and an 8mm set as I haven't decided yet.
ChrisFoley
Apr 28 2016, 07:05 PM
QUOTE(ThinAir @ Apr 28 2016, 07:18 PM)
Those are already available.
Mikey914
Apr 28 2016, 07:14 PM
Yes if you are talking about the oblong one that is as a 45 degree angle I just brought some in. I am working on the grommet at the drivers firewall for the charcoal canister currently.
sbsix
May 4 2016, 04:21 PM
I'm in for a set of 8mm and 9.5mm.
sbsix
ThinAir
May 4 2016, 05:41 PM
QUOTE(Mikey914 @ Apr 28 2016, 06:14 PM)
I missed them on the site.
relentless
May 4 2016, 07:18 PM
I'd like a set. How many are needed?
ThinAir
May 5 2016, 02:08 PM
QUOTE(ThinAir @ Apr 28 2016, 04:18 PM)
Still haven't found these on the 914rubber.com site. Would love it if someone has a link.
Mikey914
May 5 2016, 08:26 PM
QUOTE(ThinAir @ May 5 2016, 01:08 PM)
These will be up on Monday, if not earlier.
Mikey914
May 9 2016, 12:21 AM
Got these up on the site right here -
10mm
http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-18mm
http://shop.914rubber.com/Fuel-line-gromme...m?categoryId=-1The original configuration calls for a 8mm and a 10mm grommet. The picture shows both grommets with a 10mm on the stainless line. Again only one 8mm grommet is included for this selection I did this as individual parts rather than a kit so if you were doing stainless lines and opted to do both in 10mm, you could simply order what you want.
PM's going out to all who responded
