Full Version: Seat adjuster rebuild kit with optional special tool to help install
Mikey914
This is a "kit" to rebuild rebuild your seat bases. If yours look like most the factory paint is pretty crappy at this point. Now you can strip repaint and replace the bushings for your "new" seat bases.
Kit includes 4 bushings (2 seats worth) with option for the install tool. When I was playing around with test fitting these driving the roll pin was difficult with the spring there. This keeps your fingers out of the way and makes the assembly much easier.
$6.88 for the special tool and it's also in stainless! I'm sure you can find other uses for it too.
The Kit is 2 of the larger main bushings, 2 of the guide bushings and 2 roll pins $19.99.
So who's interested in a Saturday afternoon project?
Awesome. I need a couple.
Did you ever make the kit for the steering rack. I'd like to get this all in one order. Thanks.
Mikey914
The tool makes it easier to install keeping your fingers back away, and allowing you to leverage the pin into position and hammer it in.
Mikey914
QUOTE(mepstein @ Apr 28 2016, 01:33 PM) *
You know me. I will, just a matter of time.
Mikey914
installed
Can't seem to attach I went back and reduced files, not sure why?
Bossman
There's supposed to be bushings there? I'll take a set!
raynekat
OK....I give....can't seem to find them on 914Rubber website?
Are they there, or not yet quite there?
Need to add them to my growing list on your Cart.
Mikey914
Not up yet, just finishing the kits up this next week.
Mikey914
Have these up in the GB section
Outer bushing
http://shop.914rubber.com/Seat-adjuster-ou...91452120510.htm
Inner adjuster bushing
http://shop.914rubber.com/Seat-adjuster-bu...91452120310.htm
Drive pin
http://shop.914rubber.com/Tensioning-rod-f...90009501001.htm
Special tool
http://shop.914rubber.com/Special-tool-for...m?categoryId=-1
You may be able to reuse your drive pin, but they are a pain to get back in. So I made the tool. You need to keep tension on the spring as drive it in. This allows you to install much easier. I made it so you don't have to buy the package, maybe you only need to do one seat.... or you can get the whole enchilada!
Bon appetit
Mikey914
Kit is here - The tool cost a little more to make than planned, but I kept the package the same price however this GB will expire in a week
http://shop.914rubber.com/Seat-adjuster-re...m?categoryId=-1
