gereed75
Apr 30 2016, 10:15 AM
I have an aircleaner box that still has the squirter manifolds and the fuel line that feeds them.
I thought it would be cool to leave them in and mock up the connection.
Does anyone have a pix or know where the feed line for these connected and how was it routed??
Could not find it in PET or the shop manual. From what I can learn, the 911 one was connected to a T and a solenoid that was in the tunnel. What about the six??
Perry Kiehl Clone
May 1 2016, 06:18 AM
Those were disabled in a recall program. You don't want it, and really don't need it. That system is notorious for starting engine fires.
gereed75
May 1 2016, 07:18 AM
QUOTE(Perry Kiehl Clone @ May 1 2016, 08:18 AM)
Yep I know that. That is why I said I will " mock up" the installation. Just thought it would be a conversation piece that you do not see often
Not sure why they ever thought them necessary anyway. Car starts pretty well using the accelerator pumps
PancakePorsche
May 1 2016, 07:55 PM
I heard the recall was so early nearly all of the cold start systems where gone before sale. Someone correct me if wrong. I have only seen picture of one car with it once. Another rarity is the electro-mechanical decel dashpot and linkage which were removed by owners and tuners. It was a EPA thing.
Would be cool to have a disabled infamous cold start circuit however. you need to find a picture of the solenoid and fuel connection point. Also research the carbureted 911T which likely employed the same system.
gandalf_025
May 2 2016, 10:47 AM
I have never seen a complete setup on a car..
I have known my car since late 1972 and it had always been maintained by the Dealer and it was long gone, even then.
Can you say Fire Hazard??
That plus the plastic air box and the plastic air horns on the top of the Webers could make for an expensive backfire.
Would be interesting to see a complete but nonfunctional mockup on a car.
gereed75
May 3 2016, 04:09 PM
QUOTE(gandalf_025 @ May 2 2016, 12:47 PM)
Thanks for replies and encouragement. The rarity of this is what makes me want to track it down.
I see reference to the de-cell dashpot in the workshop manual, but nothing on the enrichment squirters. There are a few threads over on the early s registry. Apparently an interim fix was replacing the plastic air horns with the metal ones. At least one guy still runs it on his 911 and says it works. I have no interest in that!
I have a vague recollection of having the deceleration dashpot on my first six back in the day but am nearly certain I had no squiters
I wonder who might know more about this that has not seen this thread?
mskala
May 3 2016, 05:10 PM
I'm pretty sure I have the squirter stuff that the first owner took off, sitting in
the pile of parts in the basement.
Also, here is a couple things about the 'dashpot'.
Click to view attachment Click to view attachment
gereed75
May 3 2016, 05:57 PM
QUOTE(mskala @ May 3 2016, 07:10 PM)
Click to view attachment Click to view attachmentCool Mark, I'll show you mine if you show me yours
mskala
May 3 2016, 06:27 PM
Here is all I found
Click to view attachment You can barely see in the airbox the two holes that were plugged and the
clips that hold the lines, which may not be the lines in my pic.
gereed75
May 3 2016, 08:14 PM
QUOTE(mskala @ May 3 2016, 08:27 PM)
Here is all I found
Click to view attachmentYep, those are the lines that fit in the air box. I actually have two of the 90 degree ones and one of the tee's. I also have the outside braided fuel line that connects them. That's all I got.
Fiddle with them a bit and you will see how they fit in the air cleaner box holes and clips.
I am traveling this week and can not get pix.
gandalf_025
May 4 2016, 10:29 AM
Here is the dashpot that was removed from my car back in 1973.
Being a packrat, I kept it.
Click to view attachment This is a metal airbox from a 1970 era 911. Probably Zenith Carbs.
It still has the cold start stuff inside it, but it is welded in place on these metal
ones. This one still has the fuel line connecting them together.
But I have never seen the solenoid or the fuel line tee that fed them.
gereed75
May 4 2016, 01:11 PM
QUOTE(gandalf_025 @ May 4 2016, 12:29 PM)
Click to view attachmentCool. It appears that the metal box squirters were centered over the carb intakes. The plastic ones are Tucked. Along the side
No w the stuff is coming out to the light of day. Someone must have the rest
Is that a six snorkel? I thought all of the 911 ones pointed the other way
mskala
May 4 2016, 02:12 PM
... But I have never seen the solenoid or the fuel line tee that fed them. ...
Now I'm curious, I will look closer at the smaller bits in my collection.
Gereed, can you avoid re-including attachments in replies? It kinda gets messy.
gandalf_025
May 4 2016, 02:55 PM
Snorkel may be from a six..
Here is the inside of the metal airbox with the
fuel lines attached..
Click to view attachmentClick to view attachment
mskala
May 4 2016, 04:30 PM
Found this T and this un-braided hose.
gereed75
May 4 2016, 07:58 PM
yea, sorry. So the squirters enter at the center but then bend to the sides like the plastic box ones.
I have a spare plastic box if your interested. pM me
The only reference I found is on early s registry where they talk about the solenoid in the tunnel. When I get home I can look at the wiring diagram, ID the solenoid wires and see where they are on the harness. That would tell us where the solenoid was. This s is getting to be a PITA for some fake squiters
gandalf_025
May 5 2016, 11:40 AM
Here are a few images that show
The exhaust emissions control and a speed switch attached to the relay board.
Although it mentions the fuel squirters in the airbox, it doesn't say anything more about them.
Also, I can't remember ever seeing the water drain they mention.
A solenoid in the tunnel would mean the fuel lines were not 1 piece going through there.
I haven't replaced my original plastic fuel lines yet, but have never heard anyone mentioning a splice in them??
Click to view attachmentClick to view attachmentClick to view attachment
mskala
May 5 2016, 07:02 PM
I have never seen anything like their picture of a water drain valve.
This is the valve I have.
PancakePorsche
May 6 2016, 02:22 AM
The more I think about the cold start circuit, they had to have a thermo-time switch associated which would trigger it on at near freeze temp. and turn it off after time/temp was satisfied. That might appear on the schematic (heater and thermostatic contact) and likely located on the passenger side (914-6) cam chain cover like MFI/CIS engines. The solenoid supply had to be after the fuel pump. Would make no sense to be in the tunnel. I suspect the tee was very near pass. side carb. My car, perhaps being a late 1970 build has no extra/unused wires in the engine harness for such circuit. The mystery continues.
gandalf_025
May 6 2016, 06:04 AM
Not the greatest wiring schematic.. But it does show # 10
is for cold start..
gereed75
May 6 2016, 10:30 PM
Thanks for posting the diagram Gandalf. I got Back home last night but did not get to look at my wiring diagram yet. From the looks of that diagram, one would infer that the valve was somewhere near the fuel pump. No sign here of the temp sensor.
I will check my wire diagrams and get the wire colors and see if a can find them sometime this weekend.
PancakePorsche
May 7 2016, 01:32 AM
Found schematic. Not seen on the last list is: #41 thermo/time switch and #51 cold start relay. The relay appears to be up front on the fuse/relay panel under dash. The solenoid shown is for carbs. The top portion same as MFI. Bottom hose goes to fuel line tee.
PancakePorsche
May 7 2016, 02:03 AM
Maybe this poor guy still kept his cold start !
gereed75
May 7 2016, 07:30 AM
There it is! I am guessing the micro switches would disable the system with throttle movement?? They would have wire connections also
Judging by the length of the hose, this had to mount somewhere near the back of the air box. I bet somewhere near/under the battery tray. This is a place in close conjunction of the passenger side squirted and the fuel line feed to carbs.
Getting close to solving the whole enchilada.
PancakePorsche
May 7 2016, 12:50 PM
Those switches are for MFI car (throttle position). The solenoid on MFI engine was mounted directly on top of fuel filter console.
Has been fun seeing the detective work on this subject.
PancakePorsche
May 9 2016, 01:12 AM
eBay item number:272047811234
pete000
Jun 21 2016, 05:28 PM
I have all the emissions and cold start stuff from my early six #131
The tubes that run into the air box were disabled by being pinched at some point possibly during the recall?
Green braided hose is just a place holder.
(I have no intention of ever hooking any of this up in the future. It will all continue to live in a storage bin)
rgalla9146
Aug 15 2016, 02:20 PM
QUOTE(pete000 @ Jun 21 2016, 07:28 PM)
I think the above air filter housing is from a 911.
1. the Shell factory fill sticker is positioned so as to be read from the rear if mounted in a 911. This position makes the sticker nearly impossible to be read when installed in a 914 6
chassis.
2. the feed to the cold start squirters is on the opposite side of the engine from where the supply valve is fitted in a 914 6 chassis.
Attached is pic of my cold start valve with disconnected l wire and fuel supply hose and also my air filter with squirters still in place.
gereed75
Aug 21 2016, 09:52 AM
I guess that answers all questions remaining about this set up. Thanks all who contributed.
