JPA914
May 1 2016, 08:19 PM
I just installed the rear calipers and need to know if I should bleed first or set venting first. The pads are a pretty good distance from the rotor because the pistons are so far retracted. Also noticed my old pads didn't have the "anti-squeal" plate on the back but the new ones do. Are these worthwhile to use? The rear brakes were quiet with the old pads FWIW.
Spoke
May 1 2016, 08:35 PM
If the pistons are backed way out, it might not be wise to press the brake while bleeding. Set the venting clearance first, then bleed.
JPA914
May 2 2016, 07:06 AM
OK, is it necessary to reset the clearance after bleeding as well?
Catorse
May 2 2016, 09:20 AM
Eric Shea, the Pope of brakes, has a writeup on this. Do a search. He says to bleed FIRST then do the venting!!!!
