QUOTE(7TPorsh @ May 4 2016, 06:08 PM)
Access is the main issue...can't take the valance off since bumper is on. Have to take a look again tonight.
Be great if there was some acidic putty or gum you can just put on the bolt head and dissolve it....you know like how rust dissolves the rest of the car...
Suck, but yes you can remove the valance in your situation.
You have one bolt holding you up....
Many of us have had to deal with this..
Either a cut off wheel or a saws all will be what you need to use.
The valance may require you reach into the front trunk and cut off the ends of the bolts.
If it's the front bumper, both bolt heads can be cut off with a dremel or cut off wheel.
If it's the rear bumper, the two bolts in the trunk can be cut off easily, and the lower ones, while harder, can also be cut off with a cut off wheel.
From the picture you posted, it looks like a sawzall with a long metal blade will reach it and cut the bolt.
These are time that harbor freight is part of your new route him from work.
