QUOTE(Garland @ Nov 14 2005, 11:21 PM)
Pulling out on to the main road, under semi hard acceleration, the engine stumbled. It was like the switch was turned off, and the back on. 3 Miles later, same type of acceleration, quit and would not restart. Pulled over. Checked fuel pump, it was priming when the key was turned on. Electric at coil was good. So why won't it start? FI 1.7
Poked around and tried it again, and off I went. Well the rest of the ride when ever I went past 1/2 way with the gas pedal, it would try to shut down. Let off the gas or hard on the gas , and it ran.
When I got home I found the accelerator cable when under tension, would just touch one of the leeds on the coil and short out through a pin size hole on the casing of the accelerator cable.
Moved the cable a little, and good to go.
Same thing happen to me in 05
