Ready to go.... A perfect upgrade for your 914 or 914-6.
$1,975.00 as pictured.
Boge SC struts were jig checked, fully serviced and refinished. Bilstein Sport inserts (NOS). RTR DOT certified SS brake line set with integral Banjo fitting. Brembo calipers with strut adapters. Matched Boxster mononblocks that have been cleaned, fully serviced and refinished in VHT red, PORSCHE stencils applied and clear coated. New German 20mm vented rotors. Front hub set, cleaned, media blasted and sealed (VHT) with a new bearing set (FAG), bearing races (installed) and grease seals. Mintex semi-metallic brake pads included. These are low dust, low noise pads that work very well for street use.
Rich
a914guy@aol.com
214-796-2895
