Hello All
I recently diagnosed a clacking sound from my passenger side cv joint.
My plan was to buy a rebuilt axle unit from NAPA this spring and swap it out.
Come to find that their source is not re-building them any more.
So I located/bought 2 of these:
Bought these:
Tried to break Castle Nut loose with breaker bar and heat (MAP)- Home made penetrating oil 50/50 ATF and Acetone- PB Blaster-.
Try as I might I could not get good leverage on the castle nut.
So I went from the CV boot side and loosened the 4 bolts holding the axle to the stub shaft/Hub
Success!
Any Ideas on how to break loose the castle nut?
Was hoping to sell off the components to re-coup some cost.
I have already removed the rear brake calipers and was hoping to remove the hubs as well.
Going to follow this video to rebuild them:
https://www.youtube.com/watch?v=LsytyVzokBg
Hope they are in good shape.
Thanks
