QUOTE(barefoot @ May 8 2016, 06:42 AM)
Those caps are different side to side, (wider/narrower) make sure you've got the correct one, can't quite see from your photo.
I just put mine on last night (with engine in car which makes it a little tricky). Second one may be off as shown by OP. Did not realize they at different on each side.
Once on correct side, which end facs the exchanger?
