QUOTE(Mikey914 @ May 10 2016, 11:12 AM)
This is a thermally molded part, so I had not planned to "add" anything other that what the factory part has. The issue should be able to be be resolved using washers, I would think.
By the way, the part pictured that we will be using for molding is a NOS factory part with the sticker still in the inside. This is exactly what we will be making.
Mark,
There were 3 types of these covers:
1 - Early without the sloped front for the pre-3-point seatbelt 914s (70-71 MY)
2 - Mid for 72-74 MY with the sloped front & a hole at the spot where yours has a circle with a raised lip around the edge of where the top nut seats on the cover - to prevent the cover from cracking around the post hole.
> This is what I was suggesting you make an adaptation to the Late cover.
They had no notch in the center longitudinal ridge & on the front edge top corner for the late rubberband tie-down - which your NOS model has.
3 - The part which you show is the late 75-76 MY only form with no hole for the post/nut & has a notch for the "rubberband" tie-down.
It sounds like you've covered 2 of the 3 versions, but not the most used one covering the big production years of 73-74 (about 52,000+ with both) plus the 72 MY for about 78K cars - or about 75% of all 118000+ 914's produced.
I've seen the former late repro covers drilled for the post without any reinforcement, & invariably they will crack at the post hole, regardless of using washers. I have 2-3 in my old parts stash already.
So what you're producing now will suffer the same fate. ... as did drilling the OEM late factory cover like your casting model btw.
BTW - the posts & knurled nut come with a washer for one side anyway. The washers will not help, as you suggest above.
There were some early 80's & late 70's repros produced from the original 72-74 Mid cover with the hole/ridge, but they also went NLA around the late `80s when PP & Pelican stopped carrying them.
So you have can pick one of two ways to resolve this issue - either add a 3rd & far more common 73-74 MY type of cover with the properly moulded ridge & hole for the post/hut, & without the rubber band notches ....
... or what I suggested to cover mid & late 72-76 cars - as the reinforcement of thicker plastic - probably on the underside - so that the late type in your pic won't crack.
If you leave it as is, then I wouldn't buy one & some others won't, & you may get a lot of complaints from others who do buy them to drill the hole & have them crack.
I posted this & my above post as a helpful heads-up for you, not to head off your production of the late version.
Good Luck either way,
Tom
