Ok, got the fuel injectors cleaned out today. They were clogged but we rigged up a pressurized system and hooked to battery to make it work. All injectors spray good. The O rings are bad on all of them so I will need to replace them.
We were going to turn the ignition on to try to clear the fuel lines of the old, bad gas. But when we hit the starter, no fuel came out. We kept smelling the bad fuel, but nothing coming out of the fuel line near the engine.
Where was that bad gas smell coming from?
Fuel line had been broke below the car on passenger side. We rolled the car back and found where the fuel has been going on the ground.
So now, I have to replace the complete fuel line system. If anyone has done this and can lend some advice, I will be eternally grateful. The easier the better. If it's possible, I'd rather just run SS flexible hose thru the complete system and not have to purchase steel lines and bend it to fit. What's the best way?
Again, any advice will be greatly appreciated.
