QUOTE(RobW @ May 11 2016, 10:52 AM)
QUOTE(BfloRandy @ May 11 2016, 07:49 AM)
Hi all, I'm chasing another 914 demon so I can legitimately pass inspection. Reverse lights are out. I have replaced the switch, tried the test where you turn the car on, (without starting it!) put it in reverse, then use a pick to push in the switch where the pin would, in order to rule out a worn pin. No fuses are blown that I can find. I fear that leaves wiring. Oh, and both bulbs are still good, in fact look nearly new. What do you think?
Have you cleaned the bulbs and socket?
So, the bulbs LOOKED good... one was fine, the other disintegrated upon removal. I wrestled the remainder out, and took some sandpaper to the interiors of the sockets, replaced both bulbs. Works! I owe you a beer sir. Thank you!
