As many of you know, I was the lucky winner of a little thing Automobile Atlanta put on. I received a package today with the lenses, so here's my review and some pictures.
You might wonder why I did US spec lights instead of Euro lights, the answer is simple, because I like the look more and it's more original for my car.
First off, I should say that I am a mechanical designer with a pretty extensive history with plastic injection molded parts. What's nice is I can often easily tell how a part was made, the downside is that I can also see the shortcuts a molder takes. This is probably beneficial for many of you reading the review.
I should also say that I have no experience with the reproduction lenses AA had previously put out and their flaws, I didn't even research it because I didn't want it to jade my views on these new parts.
Alright, now lets get into it. Initial thoughts when I pulled them out of the package were that they look very nice. Plastic is a good thickness and material has a nice clarity to it.
Just like the factory parts, these lenses are three separate plastic pieces glued together, might even be plastic welded. When looking at the joints, there is a bit of an angle. The original parts have a smaller angle here, but only slightly.
I would have liked to see the ends of the seal meet somewhere other than a corner, but that's easily rectified before installation.
The threaded studs coming out of the back are over-molded, very little flash.
The homage logo, an Automobile Atlanta creation made to look similar to the Hella logo that would be on the factory parts, looks good. Placed right where the factory one would be. The rounded off rectangle that surrounds it is caused by what is called an insert, this piece of the mold can be swapped out or in this case turned around depending on if they're molding left or right side parts. Side note, if they wanted they could easily pop out some with the actual Hella logo, though it would probably be illegal.
So the part on the lens that's on the outer end of the part are clearly different molds for the left and right. The left and right mid section are made from the same mold, with the insert for the logo turned 180 degrees. So far it's all just like the original pieces, but this is where it diverts... the AA lenses use the same mold for the inner (clear, reverse) piece where as the factory used separate Left and Right molds. This would be ok I think if the design was altered for the reflector portion, but it was not. It's highly unlikely that it was a mix-up in assembly since the clear portion is not marked with a L or R like the factory pieces. Now that I've pointed it out, many of you will not be able to un-see it.
Assembly to the car went smoothly, everything lined up well and there were no issues. The lens seated down into position well when the nuts were snugged up on the backside, I didn't do a water spray test or anything but in my opinion they looked to seal well.
Overall impression is that I'm pleased. I'm not anal enough to let the clear reflector issue bug me, but I could understand if someone was. That is the only issue I see with them.
