I am working on a 73 1.7
It has the expansion tank and the canister in the front compartment and all connected correctly .
My question is back in the engine bay.
The two larger plastic hard line hoses just terminate (& not connected to anything) behind the "engine fan area"
My understanding is that 1 should be attached to the air cleaner and the other to the fan shroud to pressurize.
Here is a diagram I found ... I marked where my lines are cut (or just end) with a red line the green line shows how it is connected now.
1. should I do anything ?
2. should i connect as it should be with hose. What hose goes to what ?
3. Is there something different I should be doing ...was this disconnected and reconnected like this for a reason ?
Tnks
