QUOTE(era vulgaris @ May 15 2016, 02:29 AM)
Not sure if it's related, but my oil temp gauge started working intermittently a few months back. Most of the time it would barely register a temp, and maybe 10% of the time it would work correctly. I replaced the sender and it's worked fine since.
I've heard people say senders don't go bad, but I went through the wiring and tested it all, and also tested the gauge. The only thing left was the sender and replacing it fixed my problem.
Good points,cheap enough to replace and good piece of mind,I have seen them really dirty (oxidised) and not work properly, clean up with fine sandpaper and you generally get a higher temp due to improved conductivity.
Check to see your wiring to it is healthy,fit a new connector thats a good start if your wirings ok.
