raw1298
May 14 2016, 11:44 AM
There is a nylon or plastic bushing on mine, should I grease this or run it dry? What grease should I use if I need to?
6freak
May 14 2016, 09:13 PM
I did ...right or wrong I could`t tell you..but I lightly grease all moving parts...take that arm apart and see how the rubber bushing is mine looked OK until I removed it I made new ones from nylon dowel,,good luck
MikeC
whitetwinturbo
May 14 2016, 09:16 PM
Powdered graphite is ok.
bdstone914
May 15 2016, 07:26 AM
The wrong grease will disolve the nylon bushings. Should not need lube but Pelican does carry the correct lube.
Steve
May 15 2016, 08:50 AM
Weltmeister sold special Lube for there swaybar. That's what I used over the years. Keeps it from squeaking.
