wes
May 14 2016, 12:38 PM
I need a Oil Temp Sender part # 039 919 268 for my 74 2.0 in the Consol type.
Its just the sender that I need!
Yahmann
May 14 2016, 06:34 PM
I have a sender that screws into the oil pressure sender on top of the engine. It has 2 leads, one for temp and one for pressure. In the package VDO. I bought this when installing a temp gauge and didn't want to spend the $$ to find and buy the unit that installs on the bottom of the engine. I never installed it. This sells for $70 online - which is what I paid, I'll sell for $55 including shipping.
bdstone914
May 14 2016, 07:14 PM
That is an pressure sending unit not for temperature. See the lable? One post is for a pressure gauge and the other for a low oil light. Temperature should be measured in the sump.
bdstone914
May 15 2016, 06:28 AM
The current VDO sender is 323-055. Available for under $20 from many sources. Do a google search.
bdstone914
May 15 2016, 06:36 AM
That is an oil pressure sending unit for a 0-80 psi gauge not temperature gauge. See the lable? One post is for a pressure gauge and the other for a low oil light. Temperature should be measured in the sump.
You also paid too much. They can readily be found for around $45 new.
That wont work for the OP or you if you are trying to measure the oil temp.
Bruce
bdstone914
May 15 2016, 06:54 AM
QUOTE(wes @ May 14 2016, 11:38 AM)
It it NLA.
wes
May 15 2016, 09:23 AM
I've found that to be true but no aftermarket replacement available?
