rhodyguy
Apr 2 2005, 07:36 PM
a very bad sign.
k
rhodyguy
Apr 2 2005, 07:40 PM
very clean. al doesn't have much history on his car. interesting hub
. the bottom of his car is real clean. i'll get pictures of that in a couple of days.
k
rhodyguy
Apr 2 2005, 07:42 PM
tidy tankwell.
k
redshift
Apr 2 2005, 07:43 PM
Oh my! You have a major infestation!
Run to Home Despot, and get a Sawzall, PAAARONTO!
M
rhodyguy
Apr 2 2005, 07:44 PM
nifty backing plates. al made these.
k
rhodyguy
Apr 2 2005, 07:46 PM
another axis.
k
rhodyguy
Apr 2 2005, 07:48 PM
preweld. magnetic plates and bolts. no nuts req.
k
rhodyguy
Apr 2 2005, 07:51 PM
we also did a bump steer kit and turbo tierods. al welded engman's fine sway bar tabs. no pic.
k
rhodyguy
Apr 2 2005, 07:56 PM
a touch of dirk wright. tank out, electric washer fluid pump. "while i'm in there..."i can still get the tank in MY car out to put one in before i button things up.
k
rhodyguy
Apr 2 2005, 07:57 PM
me.
k
rhodyguy
Apr 2 2005, 07:59 PM
a wall.
k
rhodyguy
Apr 2 2005, 08:00 PM
good light for working.
k
rick 918-S
Apr 2 2005, 08:09 PM
QUOTE (rhodyguy @ Apr 2 2005, 05:48 PM) |
k |
rhodyguy
Apr 2 2005, 08:10 PM
a happy guy!!
fiddled with things a bit. tierods seem fairly parallel to the horizon, to the eye. productive day. drives pretty good. al plans to align and corner balance after he puts in the rear sway. later this week. nice car. al has personalized his car in very subtle ways. nice car.
k
Gint
Apr 2 2005, 08:14 PM
I love
Delphi Green.
Nice work guys.
rhodyguy
Apr 2 2005, 08:22 PM
i moved the sawhorses one time prior to the picture so they wouldn't be in it
. so focused on the car i didn't see them.
k
seanery
Apr 2 2005, 08:27 PM
for some reason the subject line had me a bit worried. Good job guys, nice car!
rhodyguy
Apr 2 2005, 08:41 PM
that would have never thought of that.
you need to get out more!
k
jd74914
Apr 2 2005, 08:57 PM
Nice sign. Where did you get it? We've only ever had vizsla's around here, best dogs ever
Ours is really strange though, its afraid of gun shots (and its a bird dog), but it will kill all in a manner of moles and other large rodents it finds, and sniff out mice
The sway bar install looks good too (I'm still captivated by the sign though)
ablose58
Apr 2 2005, 11:21 PM
Had a great time Kevin
I hope that I can stay up at work tonight cause I got no sleep, but we sure got it done today
AL
Bruce Allert
Apr 2 2005, 11:30 PM
QUOTE (rhodyguy @ Apr 2 2005, 07:10 PM) |
a happy guy!! fiddled with things a bit. tierods seem fairly parallel to the horizon, to the eye. productive day. drives pretty good. al plans to align and corner balance after he puts in the rear sway. later this week. nice car. al has personalized his car in very subtle ways. nice car.
k |
Kevin, that's one Bigassed Pierus. I've never seen one that tall!
Thanks again for the throttle body
.......b
rhodyguy
Apr 3 2005, 08:58 AM
bruce, hope the t.b. might help with the car. that pierus is one of the smaller ones
k
rhodyguy
Apr 5 2005, 10:33 AM
i love the smell of fill rod in the morning. it smells like sway bars.
k
rhodyguy
Apr 5 2005, 10:36 AM
s.b.
k
rhodyguy
Apr 5 2005, 10:38 AM
typical surface problem. nothing major. an 9 as far as trunks go.
k
rhodyguy
Apr 5 2005, 10:42 AM
in progress.
k
rhodyguy
Apr 5 2005, 10:44 AM
the bling.
k
rhodyguy
Apr 5 2005, 10:49 AM
i snuck in another plant.
green, green, green. beautiful car.
k
JmuRiz
Apr 5 2005, 11:46 AM
QUOTE (rhodyguy @ Apr 2 2005, 05:56 PM) |
k |
What pump did you use? I might do the same when/if I take my tank out. Car looks great.
Root_Werks
Apr 5 2005, 11:57 AM
That is cool stuff you guys! Right on!
rhodyguy
Apr 5 2005, 01:26 PM
nathan, i think it's just some generic from autozone with a switch mounted in the spare hole, on the left side of the dash face. best part is, the old crappy lines going to the wiper switch don't pee on your pants.
k
ablose58
Apr 10 2005, 08:18 AM
More fun yesterday
I changed out intake gaskets/fuel inj. seals/plenum hoses/all vac lines so no vac leaks for me
rhodyguy
Apr 10 2005, 08:22 AM
how did the car run on the drive home? after getting my lard ass out, does the car seem like the power is up? that pos vaccum line kit was a work of art
. i will be bringing my aluminum pole for the airing of grievences at the wcc.
k
ablose58
Apr 10 2005, 08:26 AM
More responsive,smoother,and more power captain
I believe kermit is about as ready as he is gonna be
Just have to hook up head temp/vac and air/fuel gauges and I will be ready to ROCK
AL
rhodyguy
Apr 10 2005, 08:32 AM
how fast thru the 45mph zone at the burley exit, 90?
i'm glad things worked out. it was a pleasure working on the cars with you, again. i edited that last reply.
k
914werke
Apr 10 2005, 12:12 PM
Al, I see those HE's are a bit rusty
How about a pair of SS units?
dinomium
Apr 10 2005, 12:19 PM
glad to see ya got the swaybar on Al... that is one sweet ride!
How about an update from Kevin?
rhodyguy
Apr 10 2005, 07:51 PM
my car is running very well. i had the car into Redmond European for a corner balance and alignment last fri. had a sneezy carb and i ironed that out today. my setup worked well before, but i have it zeroed in now. a few minor items, change oil, trim mostly. i'll be ready earlier than the day before i have to leave, unlike last year. proof my dirty engine is in the car
. rich, al has a set of new ss 2.0 ready to go. he chose to wait until after the wcc before tearing into the heating/ehaust system. smart move. his heating works like gang busters, with no leaks.
k
Aaron Cox
Apr 10 2005, 07:54 PM
kevin.... our engines are idential....
i made a cool bracket and put my breather in the same spot too
rick 918-S
Apr 10 2005, 07:55 PM
rhodyguy
Apr 10 2005, 08:11 PM
do you have the same k&n filters? mine are kind of big compared to others i've seen. i really worked the triad linkage in. fine degree of minute adjustment on the drops, you can see the nice angularity in the picture. the sycronometer read identical. don't get me wrong i still have dwd. it's manageable now. a little engine mod coming this week
. have you ever seen this aaron? dave could sell a zillion of these. 0 hassle with the valance.
k
rhodyguy
Apr 19 2005, 08:06 PM
2 guys ready to roll.
k
boxstr
Apr 19 2005, 10:24 PM
Yes that doe's look like two gays ready to roll. Kevin It looks to me like you need a big frosty Grape drink, I 'll have a six pack of them for you at CAMP on Thursday.
CCLINWELCHS
rhodyguy
Apr 17 2015, 06:20 PM
Bump for sway bar install pictures. Too hard to explain with words.
wndsnd
Apr 17 2015, 07:24 PM
Nice looking car Kevin.
914werke
Apr 17 2015, 11:14 PM
more pics of you & Al than of the job....
Let me help:
rhodyguy
Apr 18 2015, 10:39 AM
all i wanted to show were the cuts required to get the rear backing plates in place under the tank. iirc al opened the access cuts a bit to allow for the welding. when we in campbell/san jose in 05', i was at hph and 2 914s were being repaired due to no backing plates being installed. the 'phony' u-bolt method had been used on both cars and the u-bolts had torn threw the wheel well. it's an ugly mess when it happens.
914werke
Apr 19 2015, 09:45 AM
Those back plates arent required (for a street driven car) as they weren't even installed OE.
The installation I showed I didnt even pull the tank.
rhodyguy
Oct 23 2016, 02:12 PM
Another way to do the front bar.
