flmont
May 15 2016, 10:03 AM
Iam curious if carburators,...can be installed on a 92' subaru engine, or would you have to use a FI system,..??? can u re-map the ECU to run with a diffrant fuel system, I would love a 6 velocity stacked engine bay,....?? Thanks Frank
jimkelly
May 15 2016, 10:44 AM
you'd probably need to go with something like a stinger ecu if you could not use stock ecu.
http://www.outfrontmotorsports.com/engine_management.htmI don't think anyone has carbed a eg33 here, i am sure it can be done but FI is much better in general.
I say on first car, depending on skill level, don't reinvent the wheel, doing a seemingly easy swap is challenging enough without being unique.
do a sbc with stock 914 trans (rebuilt by dr evil about $1000) for simplest first conversion. plus a crate 350 runs about $2000 + carb, dist, etc. plus renegade conversion kit and cooling lit $3000 +-.
http://www.jegs.com/i/GM+Performance/809/1...VVw0aAnxc8P8HAQhttp://www.renegadehybrids.com/my sbc v8 with stock 914 trans runs about 2800 rpm at 65 mph. I could use a few more gears if I wanted to break the law
flmont
May 15 2016, 11:58 AM
hi Jim,...Thanks for the links,...I have 2 Suby engines available to me 1 3.6 no ECU,...2500.00 for link extreme ,..to run engine,..2nd 3.3 with donar car,..but need to rework ECU thru smallcar I guess,..I just thought a velocity stacked flat 6 would be cool if I could find such a set up,...?? FM
flmont
May 15 2016, 12:01 PM
My cooling system is done thanks to Guy Thompson,...here in Tucson,..I got a fabulous set-up thru him,..bent steel lines running under car and secured with Riv-nuts,.. rad shroud built and installed,..looks Great to....!!!
1stworks
May 15 2016, 12:07 PM
Ill just leave this here lol....
Maybe Ross will chime in.
r_towle
May 15 2016, 01:58 PM
You can do it either way, carbs or custom fuel injection.
Both will work
Both will require some custom work
Fuel injection probably has a lot more available with more pioneers.
Makes me want to do a carbbed Subaru
Rich
rnellums
May 15 2016, 02:00 PM
Scotty shhh! I've been working on a fuel injected Itb setup. Certainly will not work with stock fuel management. I'm planning on learning megasquirt when I implement it.
I don't expect huge performance gains(if any). The factory setup is better engineered than I would be able to achieve, but the t should look and sound pretty cool.
rnellums
May 15 2016, 02:01 PM
Jenvey in the UK also sells a bolt on ITB kit if you have the coin. Still needs aftermarket ECU though.
matthepcat
May 15 2016, 02:34 PM
Check out this one:
http://www.914world.com/bbs2/index.php?sho...=257902&hl=I went and saw it in person and almost purchased it. The builder 3d printed the intake runners and used motorcycles throttle bodies. Might be able to get a hold of him through his account.
jimkelly
May 15 2016, 06:46 PM
from what I've read here, a stock suby 6 moves a 914 real good. no need to get too fancy. start a build thread if you have not already.
flmont
May 15 2016, 08:00 PM
I would love to the sound from that set-up....!!!
flmont
May 16 2016, 04:47 PM
My next issue is a cradle,..Ian ...no answer,..and Renegade Hyb,...wants 1 k,....will be fabbing my own I guess,...Yea Jim,..I hear they can be pushed to near 300 HP ,..but,..I would be happy at 260-275 for now,..LOL
