I recently switched to the crane xr700, and of course my tach is no longer working. Which tach do I need to use now, or is there a way to get my current tach operational again?
The tach currently in the car is not original, it was changed when the engine was rebuilt, and it was wired directly from the points signal (no ballast resistor). When I hook this tach to the negative side of the coil it reads way too high. Any suggestions????
Thanks!
