I bought these from a member on here but instead decided to go with 911 hubs and a 930 axle setup for my boxster s transmission.
What you see is what you get. Notice that each hub has a slight gouge, not sure how they got there, but they shouldn't have any effect once they are pressed into the bearing.
The member that sold this to me also included the wheel studs, not sure why he gave me 12 press in style, but I'll include them as well. There is also 5 lug nut studs that screw in that will be included. I believe the intention was to re-use one of the 4 existing threaded holes to use the screw in style stud. The other 4 newly drilled holes is where you would press in the others
I'm asking 200 plus shipping
