cooper951
May 17 2016, 10:35 AM
So, the steering wheel on my '74 is mobile...will move up about an inch and a half, but normally resides in the lower position. Much more comfortable me in the raised position, but don't know what I can do to achieve this. Anyone know if something is just not hooked up correctly? I don't remember my old '75 back in the day having an adjustable height steering wheel.
Cracker
May 17 2016, 10:38 AM
What? Check the four bolts that hold the column to the chassis. Lay on your back and look up underneath the column and you'll see the four allen-head bolts - they sit within two slots. Sounds like these are loose or two are missing, allowing it to pivot.
Let us know what it ends up being please...curious.
Tony
r_towle
May 17 2016, 10:43 AM
Sumpin busted
brant
May 17 2016, 10:53 AM
not good
pretty sure your bearing is out
but that much movement, also sounds like the fasteners for the bearing retainer are loose
dangerous... check the retainer fasteners before you drive again
May 17 2016, 11:18 AM
QUOTE(Reverend Troublemaker @ May 17 2016, 09:38 AM)
cooper951
May 18 2016, 12:19 PM
Thanks all for the advice. It was, in fact, the four bolts holding the steering column up. Rather a b*tch getting to them, found it easier to remove the bottom of the dash. Much more comfortable now....and safer!
