Looking at the wiring diagram:
I have 12V at both sides of fuse 8 (B), but not at the brake switch (A).
Want to check power at the regulator plate © but have no idea what or where that is.
Thinking the next step is to pull the fuse block and check the connections and check continuity along the black/yellow wire itself.
Any other ideas?
Also the rear right blinker doesnt work.
The other three work, as does the tail lights.
So that makes me think the ground is ok, and also the stalk switch.
Cleaned the terminals and swapped out the bulb with the other side and still no workie.
When turn the blinker on with key off the other strip in the bulb comes on.
Any idea what to do next?
