My DIY tach conversion thread was originally developed to solve a single problem with the tachometer needle bounce (hunting) on the stock tachometer. Many people were asking me to solve this problem while retrofitting LED's into their gauges, but limitations of 70s style technology kept me from finding a real solution at least an elegant one.
To stereotype the 914 community, it can simply be said that we are cheap bastards.
So with cheap in mind, I found a inexpensive tachometer that anyone could buy at the local auto parts store. I then reversed engineered the cheap modern tachometer to work with our 914 tachometer as a potential solution.
This worked well but then received requests to make this work with other engines. Calculations were made for certain resistor values so that this would work with 6 and 8 cylinders which will still correlate with the stock 914 tach face dial.
I wrote the DIY thread knowing full well that many average people could or would never want to tackle this project. Instead of just listing this as a service I provide, I wanted to make it public to show people that this can be done (even by you) if you had the desire to do so, and that its possible to have a stock looking gauge with different than stock engines.
