my car is getting media blasted this week. I still have a lot of sheetmetal replacement/work to do but I want to primer the car before I continue. There's so much information out there on the interwebs it's confusing for a newbie. So.....
1. what type of coating? POR15 or just epoxy primer?
2. does the metal need a prep or wipe down before priming? with what?
3. after the primer is sprayed, do I just grind it off to do body work and then repsray? Can I apply body filler over the primer or does it go directly to bare metal?
4. Can I spray high-fill primer over the base epoxy primer?
