QUOTE(Shindog1961 @ May 23 2016, 02:47 AM)
I'm looking for a new disc and pressure plate. Are the 215mm VW parts the same? They look awfully similar and are a fraction of the price.
From memory I would say yes and no,the disc is the same but the pressure plate has different offset.
The disks were made with 4 and 6 springs but I think now they are mostly the 6 supplied by many resellers.
Inspect the pressure plate carefully if the condition is ok you can reuse them,also make sure your flywheel still has a reasonable running surface.
Shop around for your parts prices seem to vary a fair amount,good luck.
