QUOTE(DBCooper @ May 23 2016, 11:41 AM)
Remove that big nut and BE CAREFUL about order, orientation and placement of the washers etc.
^^^^ THIS
Re-install those washers and bearings and torque the shit out of it (I don’t remember the value, look it up, but you’ll be leaning into it).
and ^^^^^ THIS
is what I was talking about Mark. DO NOT permanently remove any of the washers at the end of the stack where the nut goes no matter what the directions you may find on the internet might say. You use everything except (I think) one funny looking squiggly washer that comes out to fit the sleeve on. The round smooth washers ALL go back on or the nut won't get tight enough. See my build thread for the problem/solution on that. There may be a separate thread on it as well. Paul is exactly right with everything else he said too.
And the torque value is like....160 lbs or something but it's different for every year. Mine is an 06. Sounds easy but it's not since the stubs will spin when you try to tighten it. Mine is an "open diff" which made it worse.
