QUOTE(Andyrew @ May 23 2016, 06:18 AM)
QUOTE(colingreene @ May 22 2016, 10:18 PM)
I would just suggust you dont buy one, because i have used them and had nothing but trouble with them.
Curious, can you elaborate?
Need to know what to look for..
This is second hand knowledge since I've never used one but I have some friends who have had problems with:
1) a circlip on the shaft between motor and impeller twisting and jamming the pump
2) shaft seal on motor failing and leaking water out of the case
3) the impeller binding (note that I've heard they really do not like to run dry and tend to bind when this happens)
Then there are other people who swear by them so maybe their quality control is just a little suspect. Everything mentioned about was from experiences in the 2008-9 time frame so they might be improved now. Also, make sure you do not hard-mount them by the snouts.
