QUOTE(76-914 @ May 23 2016, 03:35 PM)
That one looks nice. The one that Jim shows will splay where the pin goes thru both handles, rendering it useless. It only does this with the 1/4" nut so you need to slip a large crescent wrench over the handle to keep it from opening up when under s strain. IOW, a true POS. I like the price on the one you found as well.
Works great!! Only issue I had with it, is if you screw the rivnut on to far where the screw is past the rivnut, it will strip out the rivnut. So I am careful to make sure its either flush with the top of the rivnut or a thread below. I used it to install the early fog lights on my backdated 75 as well as fuel pump mounts, ect. I have not tried it for anything really heavy where you need to put a lot of torque on the bolt. For that type of application you should probably weld the nut to the body.
