I recently had a low brake pedal and when I went to check the reservoir hydraulic fluid was low so I filled it and noticed that there was some oxidized brake fluid in the to of the reservoir. I cleaned it up and noticed a crack in the cap. I ordered a new cap and gasket and thought that was that. But... the new cap and gasket seem to be allowing brake fluid to still back up (slowly) onto the top of the reservoir. Seems like there is some kind of back pressure. I have a 19mm master cylinder. I've looked everywhere and not leaks, peddle board off ete. etc. Any ideas???
Thanks, Tom
