zeekman914
Apr 4 2005, 03:35 PM
My friend has a VW Baja with a stock 1600 bus motor dual port with stock solex and exhaust straight piping. I was wondering why the right bank is running lean and the left is running rich. and help is greatly appreciated!
ArtechnikA
Apr 4 2005, 03:44 PM
look for a vacuum leak in the right intake manifold gasket area.
past that, i donno.
but you might mention how you determined that one side is rich and the other lean...
when you say "stock Solex" do you mean a single, centrally mounted single-barrel carburetor, or do you mean something else ?
SLITS
Apr 4 2005, 04:32 PM
When you say "straight piping" are you talking the intake manifold or the exhaust?
If there is no restriction in the exhaust (bends, mufflers, etc) you could feasibly be "over-scvangenging" the cylinder on that side...meaning the intake charge is going down the exhaust pipe and not being trapped in the cylinder.
zeekman914
Apr 5 2005, 11:07 AM
its a single solex and I will get some oictures tomarrow to show you. I will check the engine today in Autoshop. The exahust is straight piped for the most it comes out of the engine then curves to the right. I will show you later tomarrow
Thanks
Z
Jake Raby
Apr 5 2005, 11:28 AM
If that side of the engine is running hotter head temps (due to crappy cooling system or poor cooling) it will run leaner..
Hotter = Leaner
The issue may very well be in the cooling system..
zeekman914
Apr 6 2005, 01:35 PM
How would I find out head temp? He doesn't have a temp sending unit because the guy that had it before him just dropped the engine in. I do have a digital surface thermometer. Would that work?
