My engine developed a tapping noise so, I pulled the valve covers to check the clearances.
I was greeted with items shown in photo 'Big Problem 01'. It turns out that the spring washer that controls the rocker arm geometry has failed and the rocker arm has moved as shown in 'Big Problem 02'.
My temporary solution is to remove the rocker arm assembly and replace the spring washers.
Are There any problems with this solution?
Does anybody have the specs for these springs washers?
Thanks in advance.
Click to view attachment Click to view attachment
