AfricanHijinx
Jun 1 2016, 06:05 PM
Alright guys I need help. I cannot find any information on my carbs that came with my car at all and my car is running rough(lerching while cruising).
they are dual Solex H32/34 PDSI.2 carbs
does anyone else run them or have a guide to tune them?
thank you
injunmort
Jun 2 2016, 01:44 PM
i am no tuning expert but i would start with making sure there are no air leaks in the manifold/head joint and the carb/manifold joint. then proceed to make sure the linkage is adjusted properly on both carbs and finally, sync both carbs. you can get a cheap syncing meter from bug shop or amazon for $30.00. after doing that see where you are.
