ChrisFoley
Jun 2 2016, 12:56 PM
We found this while preparing to remove an engine from a customer's car.
It's a necessary component on a 914.
The part it's modified from is also a needed component, but unknown if actually off a 914.
Click to view attachmentA sideways thru hole is isn't visible in the pic.
It's pretty crusty so I won't be surprised if no one comes close to getting either the current application or the original.
brant
Jun 2 2016, 01:02 PM
it kinda sorta looks like a deformed and dirty shifter coupling half?
ChrisFoley
Jun 2 2016, 01:23 PM
It does go under the engine, but not a shift part.
EdwardBlume
Jun 2 2016, 01:26 PM
It looks like a 13mm bolt with a couple tumors.
jim_hoyland
Jun 2 2016, 01:49 PM
Easy: modified door hinge
rhodyguy
Jun 2 2016, 01:50 PM
Selector inside of a tail shifter?
dlee6204
Jun 2 2016, 03:04 PM
Clutch cable spacer?
rhodyguy
Jun 2 2016, 03:17 PM
Missed the no shifter. Is it a torsion bar/ a arm adj?
Gunn1
Jun 2 2016, 03:56 PM
It's the proportioning valve for the brake system.
Looks like it might be off a ford pickup, then repurposed for a 914 ?
BeatNavy
Jun 2 2016, 04:06 PM
Don't worry, Eric, I've got this one:
QUOTE(OU812 @ Jun 2 2016, 05:56 PM)
It's NOT a proportioning valve. It's a
pressure regulator!
Or IS it....?
wndsnd
Jun 2 2016, 04:21 PM
Its got balls on the bottom and threads on the top.
Looks like something I might do.....
But have not done yet.
No idea...
Garland
Jun 2 2016, 04:28 PM
Spring and stop for the thermostat cable?
r_towle
Jun 2 2016, 05:13 PM
Engine mount/ door hinge
EdwardBlume
Jun 2 2016, 05:17 PM
Shroud vent cover made out of a bolt.
Big Len
Jun 2 2016, 05:22 PM
Starter.
Mike Bellis
Jun 2 2016, 05:26 PM
Push rod tube...
bretth
Jun 2 2016, 05:37 PM
I think it needs to go back in the toilet.
Brett
904svo
Jun 2 2016, 06:10 PM
Brake banjo bolt used on braking system
Michael N
Jun 2 2016, 06:25 PM
Speedometer angle drive???
ChrisFoley
Jun 2 2016, 06:36 PM
QUOTE(dlee6204 @ Jun 2 2016, 05:04 PM)
You're the closest.
It's a homemade clutch fork clevis.
ChrisFoley
Jun 2 2016, 06:39 PM
QUOTE(904svo @ Jun 2 2016, 08:10 PM)
You're partially right.
A banjo bolt was the starting point to making the clevis.
rgalla9146
Jun 2 2016, 06:41 PM
fabricated clutch cable trunion
ChrisFoley
Jun 2 2016, 07:27 PM
QUOTE(rgalla9146 @ Jun 2 2016, 08:41 PM)
exactly
