JohnM
Apr 4 2005, 11:02 PM
I have '74 911RS front suspension in my car and was wondering if anyone knows what the OE torsion bar size is on that? Thanks, John
Aaron Cox
Apr 4 2005, 11:04 PM
RS suspension?
did you see the RS it came off of? what brakes does it have?
that would be really rare john...
JohnM
Apr 4 2005, 11:18 PM
Aaron-- did not see the RS it came off of. This was info from PO. Has S calipers on vented rotors. Would the spindle height be different on a 74 911RS? I could probably confirm the actuallity of what it is with that info.
Aaron Cox
Apr 4 2005, 11:21 PM
im guessing its off an RS clone....
when i hopped in your car on the ortega run...felt like 19mm T bars....
BTW - hope you didnt pay tooo much for so called 'rs suspension'
JohnM
Apr 4 2005, 11:45 PM
It may be a standard 74 911 front suspension-- would that be 19mm T-bars as OE for that year? I just would like to know what my set up is without tearing it down. If I pull the t-bar cap off would the t-bar have a number stamped on the end like the sway bar does?
Jeroen
Apr 5 2005, 05:41 AM
19mm t-bars were used in ALL 911 front suspensions
AFAIK the RS had stock front suspension except for the alu S calipers
Eric_Shea
Apr 5 2005, 08:20 AM
19mm up front and 24mm in the rear. There will be no number. You could simply slide it out far enough to put a 19mm wrench over it to verify.
For the most part, a 74 RS suspension would be the same as an S suspension of that year. They should have Bilstein (green) struts with S-Calipers (aluminum). The spindles should be standard. I believe the 18mm raised spindles were an option on some 73 cars to homogulate the RSR for racing. I'm guessing that in 74 that was gone.
I use stock t-bars on my RS clone with 930 sway-bars up front (1976 only) and in the rear. I also added the 930 rear torsion bars (26mm) because I upgraded to a 3.0 engine with similar power. The 26mm bars should help eliminate throttle squat.
