jkroells
Jun 3 2016, 03:32 PM
The rear-end of my 1976 is slightly higher than the front end. I have coil springs over shocks by Koni and they don't look adjustable. What is the best way to lower the rear-end so it matches the front end. In other words so it's level?
mgp4591
Jun 3 2016, 03:44 PM
QUOTE(jkroells @ Jun 3 2016, 03:32 PM)
I'm not sure about the Konis but the Bilsteins have multiple grooves in the shock body that locate a snap ring that fits right under the lower spring perch. Look at your shocks first to see if those grooves are there - if they are, you're good to go for adjustment. You may want to remove the shocks to do this so the weight of the car isn't resting on the springs or you can jack the car up to relieve spring pressure. You're still gonna get spring action driving against the perch so you probably want to get some small ratchet straps to contain your spring pressure. Others should chime in for previous experiences - I've only done mine off the car.
injunmort
Jun 3 2016, 03:48 PM
you can also adjust the torsion bars in front to raise it a little.
Mueller
Jun 3 2016, 03:50 PM
Options:
Raise front to match rear (free)
Cut rear springs (free, not easily reversible without spending money, trail and error, some frown on cutting springs, I've done it before and I'm not dead!)
Install adjustable collars (might not be too easy on those shocks without seeing a picture)
Install shocks that have adjustments for the springs, most $ option.
jkroells
Jun 3 2016, 04:47 PM
All good reply's. Thank you. I'll consult a mechanic to see what is the most economically best way to do it. Thank you all!
EdwardBlume
Jun 3 2016, 06:53 PM
Get a couple bags of gravel and put it in the trunk.
JRust
Jun 3 2016, 08:47 PM
QUOTE(RobW @ Jun 3 2016, 05:53 PM)
Now thats economical
zambezi
Take a picture of your rear spring/shock combo and we may be able to help without you going to the mechanic just yet.
tomeric914
Jun 3 2016, 09:37 PM
