jgiroux67
Apr 5 2005, 06:45 PM
My car has been sitting in the garage for a year and has leaked alot of fluid/oil frp, tje transmission. The oil is coming from where the linkage attaches. So how do I change the fluid in it? How do I seal it up?
Allan
Apr 5 2005, 06:52 PM
Drain the transmission, replace the shift arm seal (pretty easy, I just did it and it only took about 15 minutes) and refill.
jgiroux67
Apr 5 2005, 06:55 PM
Where do you drain and where do you refill?
Allan
Apr 5 2005, 06:58 PM
On the passenger side of the tranny right behind the CV joint are 2 big 17mm plugs. The one the top is fill and the bottom one is drain. Be sure to remove the top one first.
jgiroux67
Apr 5 2005, 07:00 PM
Thanks!
Your talking about a side shift right?
Allan
Apr 5 2005, 07:01 PM
Yep.
Dave_Darling
Apr 5 2005, 07:17 PM
Same drain and fill procedures for both.
Use transmission oil (gear oil), the nasty sulfur-smelling stuff. I use Swepco, it was very specifically recommended to me by a local mechanic. Others have their own favorites. 75/90 weight is a pretty decent one to use, though the book calls for straight 90-weight.
Auto trans fluid is very definitely the wrong stuff, even though some modern manual transmissions do use it.
--DD
